Home > Maintenance & Modifications > Tree/rock sliders and steps?
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
I installed my rock sliders more for side impact and car park dent protection more than anything and i'm thinking about fitting a set of these: http://www.paddockspares.com/pm411-defende...-pair.html and then putting a 2" gwyn lewis suspension kit on mine.
Two requests really:
Has anyone fitted these quick fit side steps and what do you think of the product?
Has anyone got any photos of tree sliders and steps like these fitted? 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top
1958 Series 1 Soft-top
Post #665434 19th Nov 2017 1:14am
Screbble
Haven't got those particular steps (I have the fire & ice) but most are very similar in terms of dimensions and fittings based on what I've seen. The quality does vary though as other forum members will point out.
I'd say half a dozen nuts/bolts a side means they are all relatively quick fix. Thumbs Up
Dependant on the type and dimensions of the tree/rock slider fitted you may struggle to actually use the steps if you fit both.
That said, only having the steps fitted myself with std cills I am only stating an uninformed perception! Thumbs Up
Good luck with the other modifications - you won't go wrong with Gwyn Lewis Thumbs Up
Post #665460 19th Nov 2017 10:03am
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
I had those type of side runners / steps on mine but over the 4 years I've had the defender I decided to change them to single side steps. Reason was for practicality as fold down side steps are easier to help get in / out of defender and also cleaning underneath is now much easier!
Post #665465 19th Nov 2017 10:58am
Offroad-Tec
Germany
Rocksliders and steps
A few photos with rock sliders + foldable steps. The rock sliders are made of 80x50x3 mm stainless steel. The normal rocksliders are 80x40x3 mm.
Another possibility are rock sliders with integrated step - we call it "grandpa's step" Smile.
Regards - Markus
Post #665533 19th Nov 2017 6:09pm
Screbble
Quite like those shown at the bottom Markus Thumbs Up
I've not seen those before.
What make are they?
Cheers,
Will
Post #665538 19th Nov 2017 6:14pm
JWL
I do a fair bit of offroading with my Defender and made up my own rocksliders with treebars as well. I had a full set of fold up original steps and found the very easy to use but even when folded up they were vulnarable
I didn't want to do away with the steps as they're really comfortable to use so I adapted mine by cutting all the folding parts off, welding some angle and they now fit by sliding the two angle iron "legs" up through the gap between the slider and the tree bar and are fixed with an M8 bolt going through a welded nut on the "leg" and against the rock slider. This pulls the leg against the treebar and locks them in place.
Yes they are vulnerable but are straightened out a lot more easily but if you know you're going to be in ruts or tight places then a 13mm spanner or socket soon removes them in a matter of minutes
I haven't got any close up pictures but try these;
Post #665617 19th Nov 2017 10:26pm
Timo K
Finland
I did this, doesn't get banged up when offroading Smile
Post #666389 23rd Nov 2017 9:01am
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
LOL, if I had to use a ‘wire-step’ like that it would be a matter of time before I lose my front teeth or break my foot. Maybe both at the same time. 😂
Post #666401 23rd Nov 2017 11:50am
rustandoil
...that wire loop step is a great idea, but I cant help thinking broken ankle Big Cry
Post #666443 23rd Nov 2017 2:22pm
Timo K
Finland
Guys, I had the same worry (it was my dads idea) but it works perfectly. No unsafe feelings whatsoever despite my fears!
Post #666445 23rd Nov 2017 2:41pm
mptzs90
United Kingdom 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
Did you work this out Kit? and if so, what rock sliders and steps did you end up using?
Post #1063323 19th Mar 2025 10:16am
