![]() | Home > Puma (Tdci) > Intermittent no power at low revs |
meeerrrk Member Since: 12 Feb 2017 Location: Surrey Posts: 548 ![]() ![]() ![]() |
I’m no expert but recently I’ve read a lot on the VCV valve, it’s function and failure symptoms.
Yours sure sounds to me like it fits one of those suspected symptoms- have a search on the forum and read up on it, see if you agree. My 90 Project : http://www.defender2.net/forum/topic52774.html |
MAC110 Member Since: 18 Nov 2017 Location: Wiltshire Posts: 3 ![]() ![]() ![]() |
Thanks for your reply .. looks like a likely suspect after a quick search around.
Just to add that outside the idle power drops .. it is fine .. I've not experienced any issues at speed or higher revs etc. Yet. I also don't get any fluctuations or chattering that others report. Fairly sure they aren't temperature dependant either as pretty cold in UK at the moment and it occured after maybe 10 minutes driving. It's apparently just been serviced by the dealer before I bought it too and have probably only done ~500 miles in it since as been in Cuba for 3 weeks (will post photos of Cuban defenders soon!) |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20676 ![]() ![]() |
Do you have an active EGR Valve? TheThunder Rolls🇬🇧🇺🇸
⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
Sorry for delay - active EGR valve is a good question - since an EGR fault flagged up under diagnostics.
It's been cleaned and lubricated and the problem seems ok for now .. but will take a look into EGR blanking plates. I'm sure there are many threads on them already. Happy days if that was all it was! Thanks for your advice. |
The EGR can put MAF readings out if any issues present which can in turn drastically effect performance in random ways. TheThunder Rolls🇬🇧🇺🇸
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17643 ![]() ![]() ![]() |
That sounds like something your GP might diagnose! "I'm afraid it's bad news, Mr McGovern, you have an active EGR valve" The power loss problem could well be VCV. |
