Home > Puma (Tdci) > Engine temperature not rising
Leviathan
Ive just replaced the SCV valve (what an absolute b*****d of a job) and tried to do the relearn routine with my BAS tool.
After sitting with the engine on tickover for 30 minutes I had to give up as the temp never rose above 68 Celcius and the routine wont start until the engine reaches 75C.
Does this mean the thermostat is stuck open? Or do I need to wait longer?
Thanks peeps.
Post #665315 18th Nov 2017 4:20pm
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
Try covering the radiator grill with a bin liner or similar, it's cold out and defenders tend to be overcooled.
Post #665320 18th Nov 2017 4:28pm
miker
Mines a td5 admittedly, but it won't get warm at idle, and even once it's warmed up, if I sit at idle for long enough it will gradually cool back down. As said, they are overcooled!
Point a fan heater at the rad Laughing
Post #665329 18th Nov 2017 4:48pm
DAZ110
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Barolo Black
Left mine ticking over for quite a while yesterday after it had been on a long run and the temp fell to 68 on my Ultraguage. Rolling Eyes
Post #665331 18th Nov 2017 4:57pm
JAY BOY
Wales
You'll never get it to temperature on tickover.
Give it a run first Thumbs Up
Post #665338 18th Nov 2017 5:33pm
zsd-puma
Take it for a good hard drive then do the calibration. Either that or you need to bring the engine up to 1500-2000 revs for a sustained period while stationary.
Post #665426 18th Nov 2017 11:26pm
Leviathan
OK thanks to your help Ive managed to get my engine hot.
Unfortunately I'm getting 'failed to complete pilot correction' message together with the number 80.
Any ideas?
Post #665491 19th Nov 2017 2:44pm
Leviathan
Ive done it now.
I tried it again after 20 minute wait and it worked.
Post #665495 19th Nov 2017 3:13pm
