Home > Puma (Tdci) > Transmission play / poor gearchange problem! |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
thanks for the tip 2.4 90 XS
28th Jan 2009 12:27pm |
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2110 |
Works,
Some time ago I had the backslash problem and was solved with this tip. regards Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
28th Jan 2009 2:01pm |
hadenough Member Since: 22 Nov 2008 Location: salisbury Posts: 11 |
mrwoo
my husband is going to try this tomorrow can you tale us were you got this tip from considering the LR enginer did not try this. |
28th Jan 2009 7:21pm |
mrwoo Member Since: 03 Jan 2008 Location: Cheshire Posts: 286 |
My Land Rover drove fine for ages then all of a sudden it became very difficult to make smooth gear changes. After several days of thinking it was my driving I thought to myself that it all started after I used low range for the first time 12months or so I go. What happened was that when I went back to high range the low/high ratio lever was not all the way back into position, despite the fact it still drove in high. This has happened a few times for me now but at least I know how to cure it now. My PUMA has done 30k miles now and the transmission is as it was when it was new, apart from when I forget about this! As I said earlier, you only know when the lever is all the way back when you apply a slight amount of pressure pulling the lever back into the high range position while in 1st and letting the clutch off slowly, you can then feel it going all the way properley as the gears mesh together. This cannot be felt by just yanking the lever back as far as you can assuming it's all the way in. Is anyone aware of this ever happening on the TD5, it never used to happen on my 300 Defender before this one. Good Luck, I'me sure it's not a cure for everyone but it's worth trying |
28th Jan 2009 7:45pm |
