Home > Maintenance & Modifications > Wiring route to Heated Windscreen
rallysteve
Would someone with a 2 tab type heated windscreen (preferably factory fitted) mind looking at where the wires are routed to the screen and how they are terminated to the screen please.
I am just putting the wiring into my replacement wiring loom and unsure what length/route they take to the screen.
Cheers,
Post #664480 15th Nov 2017 11:14am
Spade connectors (can't remember the size but I think 6mm), one in each lower corner.
Post #664501 15th Nov 2017 12:46pm
rallysteve
cheers, I presume the wires follow the same route as the loom running up the A-Pillar does on the RHS?
Which orientation are the terminals, cant quite make it out on the photos online from VGS
Post #664513 15th Nov 2017 1:30pm
rustandoil
The wiring doesn't get as far as the A pillar, it just comes out between the top of the dash and the screen rubber
Post #664514 15th Nov 2017 1:34pm
Martin
Site Admin
6.35mm Posi-Lock are the original fit, they latch onto the screen tabs.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #664516 15th Nov 2017 1:40pm
dorsetsmith
TD5 02 to A6 heated windscreen main power wiring 4.0 mm2 in main balk head loom pos wiring down to the relay centre fuse box and neg runs down driver seat box
Post #664519 15th Nov 2017 1:53pm
