![]() | Home > Technical > Electric Window fault |
Any more info than "a fault"? That's a bit vague!
![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
Probably a snapped wire in the rubber boot between the door and post
under_rover Member Since: 02 Apr 2013 Location: Yorkshire Posts: 152 ![]() ![]() |
Won't go up or down....I've put a separate supply on motor which worked, swapped fuse and swapped switches over with each other.
So I suspect either a break in the loom or could there be another connection somewhere that may have come adrift? |
Almost certainly a break in the wires leading to the door as mentioned above. It's a common fault. Darren
Yep.... that was it.... a broken red wire in the rubber boot....cheers for your assistance
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2237 ![]() ![]() |
Drivers window stopped today .
Forget using the solder iron as the solder won’t take to the cheep LR wiring of the loom . Managed to make the incision in the exact right place and guess what I found ? Notice the blue also on the way out so both repaired with extended length of new wire. ![]() Click image to enlarge |
It must be the cold weather as my central locking stopped working on my drivers door last night but worked again this morning
![]() My build thread http://www.defender2.net/forum/topic17615.html |
Cold weather
![]() It’s positively balmy up here and I got eaten by midges whilst changing out the wires . ![]() Keith |
Cold weather stops mine, I'm sure it's snow shy as its broken down twice the week the snow started
![]() ![]() My build thread http://www.defender2.net/forum/topic17615.html |
I'm glad it was an excellent summer when mine went pear shaped, had to drive all the way home from Scotland with the window fully down
