Home > Technical > Heated mirror wiring |
The time has finally come to fit my mobilecentre heated screen wiring kit (only taken me about 3 or 4 years to get round to it) but I'd like to wire my heated mirrors (also not connected at the moment) in on the same switch. My question to you knowledgable people is, do I just take two feeds (one for each mirror) from the positive wire of the screen feed to run to the mirrors and then Earth the mirrors to the door? In my mind this is right but thought I'd better check
Any help appreciated Cheers Ray Ray My build thread http://www.defender2.net/forum/topic17615.html |
14th Nov 2017 3:36pm |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1232 |
Ray,
This link may help: http://defender90xs.blogspot.co.uk/2014/10...ation.html Regards |
14th Nov 2017 3:40pm |
thanks for the quick reply. The difference with mine is the heated screen wiring is not factory so as everything is already in place my thinking was that I just need to connect the live feed to the screen to the live feeds to the mirrors. Electrics seem to twist my mind for ages then one I look at them and everything seems obvious this is one of my off days. Ray
14th Nov 2017 3:51pm |
That's great Jim thanks the weather man says it's going to be dry tomorrow so I thought I'd put it in. I saw the numbers on the connector flap so hopefully I'll get them in the right place
14th Nov 2017 6:29pm |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2102 |
Good luck Ray
The sun always shines in Huddesfield so no excuse. |
14th Nov 2017 7:14pm |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1423 |
Its the 3rd one I've done!! I must have been lucky on the other 2
Made a hole top of seat box across the transmission tunnel and up behind the fuses. Loads of room |
14th Nov 2017 7:16pm |
thank you Will but I think you've been misinformed, it's never sunny in Huddersfield Ray
14th Nov 2017 7:17pm |
I think I'm going underneath and up the bulkhead and through the rubber grommet behind the dash Ray My build thread http://www.defender2.net/forum/topic17615.html |
14th Nov 2017 7:21pm |
