Home > Td5 > Repair fork 576138
JediG
Russia 2006 Defender 90 Td5 HT Sumatra Black
Repair fork 576138
Hello!
Has anyone done the recovery of the clutch fork 576138 engine TD5?
The plug is in perfect condition. I would not want to buy a new fork. For some reason, Land Rover did not foresee the replacement of rod insert. I would like to find a suitable budget solution for the restoration of this part.
Maybe someone has already done this?
Post #664128 14th Nov 2017 7:08am
dorsetsmith
1. have used bearing fit you will need clean both parts before using bearing fit
2. in the field have used centre punch and hammer with push rod insert in place in the fork with centre punch and hammer centre dot at there point it will lock push rod insert in place
Post #664134 14th Nov 2017 7:31am
JediG
What bearing do you recommend to use?
Post #664140 14th Nov 2017 8:07am
dorsetsmith
Loctite 641 - Medium Strength Bearing Fit Retainer 10ml
Post #664143 14th Nov 2017 8:11am
JediG
Where can I get a rod insert? The one that was broken.
Post #664154 14th Nov 2017 8:53am
