Home > Maintenance & Modifications > Puma VCV Post Mortem
Bluest
I replaced my Volume Control Valve or Suction Control Valve (SCV) today after the cold weather brought my lumpy idle back. New valve has fixed the idle so thought I'd dismantle the old one. I think this has been done previously by another member but I couldn't find the thread.
Inside the the valve the valve is a piston under spring pressure. The piston has a few orifices and looks to be ground very accurately and maybe heat treated too. On my old one the surface finish on about a quarter of the sliding surface was worn to the point you could feel the roughness with a finger nail. O suspect this is what causes the problem as it will probably be causing the piston to stick in the bore and not move smoothly.
Picture of the valve assembly:
Piston from two angles showing the smooth side the the worn rough side. Camera phone is rubbish so it might not be clear enough
 2007 110 TDCi Station Wagon XS
Post #663476 11th Nov 2017 4:05pm
I have no doubt you'e right, and more often than not it will be moisture from the fuel which starts the surface deterioration.
Post #663509 11th Nov 2017 6:33pm
ickle
opening up the old can of worms (no not brexit Rolling with laughter ) do you suppose adding 2 stroke will help prevent this?
Keith
Post #663511 11th Nov 2017 6:37pm
agentmulder
Kuwait
Interesting. I think I kept my old one too, when I stumble across it next I'll do the same. Solved the bowel problem, working on the consonants...
Post #663620 12th Nov 2017 12:07am
smb
Hi Bluest,
Having just changed a vcv(last weekend) following a month of lots of white smoke(smell of unburnt diesel) on cold start up and other running issues and having read this thread I decided to do the same. And low and behold mine looks identical. Polished finish on about 270-300' of the circumference on both the long and the short cylinders with the remainder looking very slightly rough. Looking down the length all the marks/edges of roughness were in line so it looks like it wasn't rotating inside.poss due to lack of lubrication.
It has lasted 145,000miles though of which the majority had 2-stroke added so maybe that's a positive for 2-stroke. Who knows? I wonder what lifespan a vcv should have? It's amazing how such insignificant looking wear can have such an effect.
Will post photos when I have access to broadband, but they look almost identical to yours.
Post #663745 12th Nov 2017 4:51pm
agentmulder
Kuwait
Would be good to open a new one for comparison huh? Solved the bowel problem, working on the consonants...
Post #663803 12th Nov 2017 8:08pm
Bluest
I think it’s safe to say a new one wouldn’t have those marks. Whether the marks are what actually cause the poor running or there’s is another fault is hard to say. The Piston seemed to still slide smoothly and freely enough. I’m not actually how the valve works. I assume there is a coil in the body that moves the piston like a solenoid or something. 2007 110 TDCi Station Wagon XS
Post #663820 12th Nov 2017 8:26pm
