Home > Wheels & Tyres > 265/75r16 on boosts
Djcla
265/75r16 on boosts
I just want to check before I finally buy my stt pro's in this size that I won't need spacers on standard setup 90? Reading a few threads it's not 100% clear to me.
Post #663145 10th Nov 2017 3:53pm
barbel jim
you'll be fine. Thumbs Up You might need to adjust the steering locks if you get rubbing on full lock
Post #663147 10th Nov 2017 3:58pm
Djcla
Is that easy?
Post #663151 10th Nov 2017 4:13pm
barbel jim
yes, and only necessary if they catch
5th post down has a picture Thumbs Up
http://www.defender2.net/forum/topic39311....ring+stops
Post #663153 10th Nov 2017 4:17pm
dorsetsmith
STEERING
ADJUSTMENT
STEERING LOCK STOPS
Service repair no - 57.65.03
Check
1. Measure clearance between tyre wall and radius
arm at full lock. This must be not less than 20
mm.
Adjust
2. Loosen stop bolt locknut.
3. Turn stop bolt as required.
4. Tighten locknut.
5. Check clearance between tyre wall and radius
arm on each lock.
NOTE: Alternatively lock stop adjustment
may be carried out using following
procedure.
Check
1. Measure stop bolt protrusion �A�. Refer to table
for correct setting.
Adjust
4. Tighten locknut.
5. Check wheel position at full lock.
LOCK STOP SETTINGS
Tyre & wheel size - alloys
Make
Size
Setting
BF Goodrich Mud Terrain
265
59,7 mm
Goodyear GT+4
235
55,7 mm
Michelin M+S 4x4
235
54,2 mm
Tyre & wheel size - steel
Make
Size
Setting
Goodyear
205
52,2 mm
Michelin
205
52,2 mm
Avon
7.50
56 mm
Michelin
7.50
56 mm
Goodyear
7.50
56 mm
Post #663155 10th Nov 2017 4:32pm
Djcla
very useful thank you, i may still op forthe 235/85/16 yet , ive been going back and forth in my mind for months now lol. SHame i cn buy both sets and see what looks best Smile
Post #663162 10th Nov 2017 5:07pm
barbel jim
I have both Whistle Prefer the 265 IMHO the 235 is a bit skinny, especially with spacers... Buy the 265, then you can swap for my 235 Mr. Green Whistle
Post #663168 10th Nov 2017 5:17pm
Djcla
do you have stt Pro's?
Post #663170 10th Nov 2017 5:22pm
barbel jim
No BFG at
Post #663172 10th Nov 2017 5:25pm
Djcla
so did you have to adjust your steering stops? Ill probably go with the 265's in the end its just a lotta cash for 5 tyres Sad
Post #663175 10th Nov 2017 5:26pm
barbel jim
Only ever had to adjust on the new puma to increase the turning circle when it was supplied. I know someone who fitted new tyres and had to alter his slightly though...... Same brand and tyre as take off just new Rolling with laughter
Post #663176 10th Nov 2017 5:31pm
L90Andy
United Kingdom 1997 Defender 90 300 Tdi ST Nato Green
Having had both (of the same tread pattern) there are pros and cons to each.
235/85: Better on fuel. Quieter. Cuts through standing water, snow, mud better. Shouldn't worsen steering lock. Doesn't spray too much muck up the sides.
265/75: Look better. Floats on bogs better and erm that's about it!
I like 255/85's best, ideally on Wolf rims!
Good luck with the decision! Thumbs Up Instagram: L90andy
My 1984 Ninety: http://www.defender2.net/forum/topic56071.html - SOLD!
My 2015 Defender: http://www.defender2.net/forum/topic39625.html - SOLD!
Post #663178 10th Nov 2017 5:42pm
Djcla
255/85's ah man didn't even know that was an option on standard boosts?
Post #663182 10th Nov 2017 5:54pm
L90Andy
Yep, Boosts are 7" wide and 255's will go on anything over 6.5". They are a taller tyre so you'll get more clearance than either of the other two so would affect your gearing more. They also tend to come in MT pattern only. All depends what your requirements are. Instagram: L90andy
Post #663190 10th Nov 2017 6:21pm
L90Andy
Sorry, totally distracted you from your original post! The answer as mentioned above is, yes 265's will fit. A very common and capable fitment. Go for it Thumbs Up Instagram: L90andy
Post #663194 10th Nov 2017 6:27pm
