![]() | Home > Technical > Adding heated elements to rear seats |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 672 ![]() ![]() ![]() |
Cable routing might be tricky so the don't get damaged when folding?
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1237 ![]() ![]() ![]() |
No help but mine have them built in - haven't wired them up yet though... (very bad photo - but it's a set of L322 seats in there).
![]() Click image to enlarge It would be tricky but my suggestion would be to, if you could, route the wires through the frame itself - drill a hole at the top and bottom and have fun feeding it through! Another alternative would be to connectorise them at the seat bases on the floor so if you need to fold them you can simply unplug them. Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
Justtellme Member Since: 23 Nov 2015 Location: Ottawa Posts: 310 ![]() ![]() ![]() |
I bought a couple of kits from ebay and installed them.
Not finished wiring them up externally yet,....or even installing these new puma seats in my TD5 yet, but not too difficult a task. I used zip ties rather than new hog rings to make it simpler. Patrick ![]() Click image to enlarge ![]() Click image to enlarge |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
i retrimmed a few sets of seats of various cars. Small zip ties are so much easier than hog rings!
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8204 ![]() ![]() ![]() |
i was looking to disconnect them when i fold seats fwd.
so how do you get into there in the first place? Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
