Home > Technical > Td5 90 - Duck under the bonnet!
Timbotim
United Kingdom 2002 Defender 90 Td5 HT Epsom Green
I have been experiencing a rubbing like noise coming from what sounds like the front drivers side wheel. It is intermittent (tends to return after a bit of off roading) but then persists for a while. My wife describe the noise as sounding like there is a duck under the bonnet, this is a fairly accurate description.
My first thoughts were towards the swivels, but upon further inspection and re-greaseing that appears to not be the problem. The break pads and discs also appear to be fine.
Any suggestions would be greatly appreciated
Post #661388 2nd Nov 2017 10:29am
ibexman
Try spraying all the wheels on the serpentine bells with spray oil alternator ps pump
Post #661390 2nd Nov 2017 10:38am
TD5Neil
I think I may have the same issue. Woop woop rubbing noise, intermittent, persists for a while and then gone for a couple of weeks before returning. Worse when cold, gets better when warmed up. Sometimes starts up when turning to the left, eases when backing off throttle. Worse if it's been wet, started up again after a wash and been with me for a couple of days. Checked wheel bearings and swivels for play, also UJ's. Really odd it can go away for 2-300 miles and then return.
Post #661524 2nd Nov 2017 9:02pm
Djcla
i have a similar noise first thing when i put my foot on the clutch but it goes away once warmed up and i assumed it was the Dual mass flywheel or something . I just turn the radio up Smile
Post #661616 3rd Nov 2017 10:48am
ibexman
That’s clutch release bearing very common
Post #661617 3rd Nov 2017 10:50am
dorsetsmith
sawtooth tyre wear noise
https://www.oponeo.co.uk/tyre-article/saw-tooth-tyre-wear
had same problem
Post #661618 3rd Nov 2017 11:08am
TD5Neil
Djcla - your noise does sound like release bearing. My noise goes when clutch depressed.
Dorsetsmith - would sawtooth tyre wear be intermittent?
Ibexman - I'll look at the belt
True to it's intermittent nature no noise on the way to work today. Previous 3 days it was there!
Post #661620 3rd Nov 2017 11:26am
Djcla
Is that a cheap job to get done or are you better off doing the clutch etc at same time? I got 170k on clock and not aware of any major work in its past.
Post #661783 4th Nov 2017 8:41am
Diffy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Corris Grey
Timbotim - when you say you regreased the swivels do you mean you refilled them with one shot?
Reason I ask is I had a very similar sound noise somewhere between a duck quacking and a seal begging for fish !
Seemed to occur at low speed when turning left
My noise was banished by refilling both swivel hubs with one shot - both of mine appeared to be dry
Post #663705 12th Nov 2017 1:46pm
