![]() | Home > Puma (Tdci) > Strong vibration in the gear shift lever |
CyberCharlie Member Since: 01 Jul 2010 Location: Reading Posts: 140 ![]() ![]() ![]() |
Hi guys,
110 Puma, 2007, 2nd hand. Generally works pretty well. Only at times at around 2200 RPM the gear lever vibrates and rattles. Does anyone know how to fix it? if i look at the stick, i see that the outer shell is slightly detatched from the upper knob (i hope i made myself clear) I am pretty sure that there was some similar discussion on the site but culd not find it. Little help please??? ![]() |
Is it something i can try and fix myself over a weekend? |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 ![]() ![]() |
Only if you buy a new gear stick unit..... I would delegate to a indy or LR outlet. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Good point. I'll have to speak to the dealer... |
FG Member Since: 01 Apr 2011 Location: Somewhere on the Swedish East Coast Posts: 63 ![]() ![]() ![]() |
I've got the same issues with my 90 SW. The gearstick vibrates and rattles, especially when you work the engine hard. Problem is, mines a 2009 and from what I can gather from previous posts this issue was sorted with models from 2009 and on?
ralton Member Since: 04 Feb 2010 Location: Durban Posts: 153 ![]() ![]() ![]() |
mine had it as well - you need to replace both the gear stick and selector plate.
my understanding is that it isn't a big job. makes a huge difference once it's done, so quiet and smooth! www.ralton.co.za |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5068 ![]() ![]() ![]() |
It was the selector on mine...not the gear stick Mike
cinstone Member Since: 29 Nov 2010 Location: Stourbridge Posts: 375 ![]() ![]() ![]() |
Got the same problem on mine under any load from about 1800 rpm. Told the dealer that the engine/gearbox had to be warm for it to happen, then to be told, when I asked them, that they took it round the block and couldn't find anything wrong
![]() ![]() ![]() Now it's out of warranty ![]() However, I have a fix. Turn the radio up! Chris. |
s18mcn Member Since: 11 Feb 2011 Location: cambs Posts: 51 ![]() ![]() ![]() |
Mine does exactly the same on a 57 plate but stops when you hold the gearstick.Did this problem come up as a bulletin which could be repaired by dealer even if the truck is out of warranty?
Not that I know to.
Chris. |
