Home > Td5 > TD5 losing fuel pump
fondelli
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
I have an intermittent issue. Basically everything runs fine, then I lose the fuel pump and the engine cuts out. I thought it was the yellow main relay beside the under seat fuse box. I changed this for a new one and drove 60 miles yesterday with no issue. This morning it happened again one mile from home. I removed the seat base and cover and gave everything a tap and off we went again. Thoughts? Could it be one of the blue headers beside the ecu?
Post #658986 22nd Oct 2017 6:14pm
bob neville
Have you tried closing the contacts that the relay slots into ? They are known to open and you then end up with intermittent problems.
2013 Defender 90 CSW - sold
Post #659001 22nd Oct 2017 6:48pm
fondelli
Contacts are good
Post #659007 22nd Oct 2017 7:00pm
fondelli
update- could it be header 291?
Could it be this? I assume this is below seat beside ecu?
Post #659458 24th Oct 2017 6:58pm
