![]() | Home > Maintenance & Modifications > LED Rear Lights |
300TDi CSW Phil Member Since: 03 Apr 2016 Location: Bracknell Posts: 750 ![]() ![]() ![]() |
I assume you have the "normal size" of 73mm diameter rather than NAS style about 95mm from memory.
The two main manufacturers of such items are Wipac and RDX. I can't vouch for the RDX ones as I have the Wipac version fitted to my defender and they have been superb for the last 4 years. They are plug and play with the correct connectors and even come with new screws. Your favourite Land Rover parts place is probably as good a bet as any for picking them up. I did think that Brendan sold them but cannot see them on his website. 1995 300 Tdi Epsom Green - It's a keeper. Wide Track Sankey- In bits- Gone to a new home M0XQS |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2109 ![]() ![]() ![]() |
I've had RDX fitted for a few years and they've been spot on. The bay of e lists most of the RDX offerings.
They look like the originals even close up - I wanted to retain the factory look. No fiddling or modifications required - plug and play. they make a significant difference in terms of others being able to see you, however we are benchmarking and comparing to the originals which are poor to say the least. Wipac have good reviews also as Phil has testified. Hope this helps ![]() |
CEEGEE Member Since: 02 Oct 2013 Location: Yorkshire Posts: 135 ![]() ![]() ![]() |
Thanks chaps, very helpful
![]() The Land Rover ones are terrible - can't believe I've not done it before now ![]() |
Ramsay Member Since: 30 Sep 2015 Location: Moffat, Dumfries & Galloway Posts: 632 ![]() ![]() ![]() |
Had the RDX ones fitted for a couple of years. Look very similar to the originals. They were very easy to fit with same connections as the originals.
You only mention stop and tail lights. They are straight swop. If you fit the LED indicators you need to change the relay to the adjustable one that RDX sell. 1995 Defender 110 CSW 1971 SIIA Lightweight |
Yes, just planning to do the tail / stop lights for better visibility with winter on the way
![]() Fairly happy that the indicators do the job okay ![]() |
You should be able to get the stop/tail LED's for less than £20 if I recall.
The distance you can be seen from is significantly increased which as you say will make a difference as the nights darker nights draw in. Hope you get them and have no problems with the fitting as its effectively a direct swap ![]() |
cyk1 Member Since: 11 Sep 2017 Location: London Posts: 7 ![]() ![]() ![]() |
Has anyone fitted the black pack LED lights from Nakatanenga? Pics would be great. Are they really plug and play? Really do not want to start drilling new holes!
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1366 ![]() ![]() |
Wipac full kit on mine with no issues
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2535 ![]() ![]() ![]() |
Likewise. Wipac LEDs stop tail and rear indicators. Plug and play. Had them fitted for over two years and no problems. Defender 90XS SW
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6641 ![]() ![]() ![]() |
You can upgrade pretty easily to the 95mm NAS/SVX type LEDs too if you want more lamp surface area
There's at least one person that's fitted the Nakatanenga lights. See here: http://www.defender2.net/forum/post654588.html#654588 Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
95mm OEM lamps:
![]() Click image to enlarge No bodywork drilling, totally reversible. ![]() ![]() |
Thanks guys. I think the black leds will look good against my Stornaway 90!
