Home > Puma (Tdci) > roll cage please
Page 2 of 2 <12
apt100
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Aintree Green
boode wrote:
The bulkhead is replaced with a new bar that is part of the cage - also has a bar under the chassis to further strengthen the structure
I did not install the rear supports - I think they were to give a fixing for rear seat belts but I have no rear seats
Thank you.
That is interesting. I have seen SD cages before where the bottom bar of the cage is fitted as well as the standard bulkhead replacement bar (ie factory fitted on Puma SW). This always seemed a waste of space. Your cage does away with the standard bar which makes more sense.
I'm still a bit unsure about the rear stays and how they fit with factory Puma folding rear seats.
Post #658175 18th Oct 2017 7:04pm
Welshsurferdude
Wales
unsure who made my cage as I got it second hand from matt spencer of carriage autos who broke a few 110 TDCI's that were fprmer site vehicles. looks good on mine though Smile £850 all in including fitting.
 2011 Santorini Black USW XS.
2015 Discovery 4.5 Black pack Firenze red XS
Post #658189 18th Oct 2017 7:49pm
4wheeler
Australia 2013 Defender 110 Puma 2.2 SW Chawton White
100inch wrote:
I got that cage on my 110 2010 and it comes with an internal hoop, right behind your seats. The bulkhead comments are only for 90's and I even got the LR OE cargo barrier fitted. You can do it by yourself but count 2 to 4 days unless you want to rushed. I also added Dynamat at the same time as the interior has to come out. m
Hi 100inch,
I am looking at an internal style cage. In Victoria (Australia) where we are located, internal roll over protection including a single hoop needs to be certified by a Vic Roads signatory otherwise it's not legal. Were you able to get the internal cage certified? I am looking at the L255 Safety Devices cage but doubt I could get it signed off in Victoria as the seat belt mounts are changed and the base plates seem to below the minimum size specification required. I rarely carry rear seat passengers. It might well be able to be signed off but it is a big expense to import one only to find out it might not be legal.
I have modifications such as a Safari snorkel which means I can't and don't want to fit an external cage. I know with the external cages we can call it a roof rack (very strong roof rack) and hence not require certification
Any advice appreciated.
Regards
4wheeler
Post #658333 19th Oct 2017 10:23am
Page 2 of 2 <12
