![]() | Home > Tdi > Drivetrain slop checklist? |
yostumpy Member Since: 01 Aug 2010 Location: n/kent Posts: 327 ![]() |
I'd start by checking / replacing the uj's (all 4 of then),and then the spline end caps for the driveshafts, go for the hD ones with the octagonal screw on caps (COPPERGREASE!!)
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 ![]() ![]() ![]() |
It had a new propshaft a while back but i'm not sure if everything was replaced 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top 1958 Series 1 Soft-top |
Blackhat90 Member Since: 31 Dec 2016 Location: Forfar Posts: 86 ![]() ![]() ![]() |
Rear radius arm bushes, front radius arm bushes [ torque steer when excessive wear] lastly A frame bushes, the ball joint is usually a big clunk when worn ,
Hendrix Member Since: 04 Oct 2016 Location: North Notts Posts: 104 ![]() ![]() ![]() |
Mine was rear diff play which lead to eating drive flanges so definitely worth tracking down cause.
MGCarr Member Since: 18 Nov 2016 Location: Lancashire Posts: 59 ![]() ![]() ![]() |
+1 for the ball joint on the A frame, I replaced mine a couple of weeks ago, it did not feel badly worn when levered with a big bar, only about 1mm of play but a new Lemforder OE spec ball joint has completely transformed the feel of the whole drive train. Probably the most effective £30 I have ever spent on a Land Rover. |
