Home > Maintenance & Modifications > Battery charger
tolley
United Kingdom 2006 Defender 90 Td5 CSW Oslo Blue
Battery charger
Anyone recommend a battery charger, 6v _ 12v ? Mines just backed up .
Post #657949 17th Oct 2017 7:04pm
Sulisuli
ctek battery chargers are excellent. 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #657955 17th Oct 2017 7:11pm
tolley
Thanks, I will have a look
Post #657959 17th Oct 2017 7:23pm
Sulisuli
Not cheap but I have one for my boat and one for the Defender and never had a problem, worth the investment I feel. Do a search on here for members thoughts on them. 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #657962 17th Oct 2017 7:30pm
jst
i have used airflow for the last 20 years or so http://www.airflow-uk.co.uk/Battery-Conditioner.html 6,12 and 24v oneshttp://www.airflow-uk.co.uk/3-Step-Battery-Charger.html
tried Optimate (?) they dont last the test of time in my experience.
C Tek have good reputation to, never tried them though. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #657976 17th Oct 2017 8:03pm
nitram17
ctek Thumbs Up
Post #657978 17th Oct 2017 8:04pm
Swine&Small
100 per cent we have 3 of them excellent Thumbs Up 1983 Series 3 Pick up in Marine Blue
1967 Morris Traveller
1966 Morris Convertible
2012 VW T5 Camper
Quod Abundat Non Obstat.
Post #657980 17th Oct 2017 8:10pm
xcentric
+1 ctek
but also look out for Lidl and Aldi sales - theirs are far cheaper, and certainly used to have the same inners as some ctek's. In general they are less flexible, and slightly worse at detecting completely flat batteries (mistaking them for 6v ones) but I manage a few vehicles with one ctek and 3 aldi/lidl ones.
Post #657984 17th Oct 2017 8:49pm
Ellisboy
1998 Defender 90 300 Tdi CSW Epsom Green
Aldi have them in at the moment,I’ve got a Lidl version for the toylander ,good for the money £15 ish Thumbs Up
Stephen.
Post #657986 17th Oct 2017 8:54pm
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
I use a Ctek at which is permanently plugged into the Defender whilst I'm away and it works perfectly. It lives outside all year round and no problems yet. Used a couple of the Lidl versions also and they have done everything from a motorbike to a CAT backhoe without any problems.
The Noco Genius range are meant to be very good also. 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #658019 18th Oct 2017 6:11am
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
jst wrote:
tried Optimate they don't last the test of time in my experience
Ditto that. I have a dead one on the shelf. It was useful in that it did both 12V & 24V (the 101 is 24V) but the main transformer died and that isn't a standard spec component.
For years since that died I've been using a Farnell TOPS3D laboratory bench power supply for battery charging. It has resurrected many batteries that "smart" chargers have refused to consider and is also useful for other diagnostic work. If I want more current I've got a huge Hewlett Packard 19" rackmount PSU Very Happy
Post #658047 18th Oct 2017 8:59am
miker
CTEK MXS5.0 is a good balance between cost and performance
Post #658048 18th Oct 2017 8:59am
zsd-puma
The Lidl ones are excellent. They're basically the same as the Ctek's.
I've got a Ring Smart charger, I don't know how important the 6v side of it is, but if it's just a nice to have then these are excellent. Also does battery and alternator testing as well as the full compliment of charge cycles with a nice unambiguous interface.
http://www.halfords.com/workshop-tools/gar...ng+charger
Post #658060 18th Oct 2017 9:47am
Martin
Site Admin
One difference with the Lidl/Aldi chargers and the CTEK is that if you are using them for long-term trickle charge (over-winter for example), then they do not start charging again after a power cut. CTEKs do.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #658084 18th Oct 2017 11:41am
Swine&Small
Did not know that, as I am in an area prone to power cuts , I am pleased to have the Cteks.
2012 VW T5 Camper
Post #658087 18th Oct 2017 11:46am
