Home > My Defender > Seapod's 90XS SW - First mods here we come!
Page 3 of 3 <123
Seapod
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Santorini Black
Next task was sorting the headlights: Crystal WiPACS with Osram Laser Nightbreaker bulbs. Maintain OEM look but increase vision. Old on the left, new on the right.
Now - I bought the Boomslang wiring loom to sort out the switch problem but haven't fitted it. Why? Because I have started finding tales of the loom failing and potentially causing a fire risk. It seems particularly vulnerable around the fuse and relay area. The forum has a number of tales of woe caused by the loom (and the Landzreiger too to be fair).
Secondly, I also found a couple of threads suggesting that the switch issue was fixed post 2011 (there was a LR recall for 07-11 models I believe).
So on balance, do I leave everything alone? The new lights are super bright and voltage at headlight is good. Thoughts? My Defender: http://www.defender2.net/forum/post630322.html#630322
Post #657057 13th Oct 2017 12:55pm
Seapod
On another matter....
I couldn't believe how simple it is now Pete has managed to crack the tuning of the ECU with no removal. Total elapsed time from start to finish (including sending Pete the file and receiving the map back from him) just over 1 hour. Actual time 'doing things' about 10 mins from start to finish.
Thanks to all who suggested this as the next significant mod, its phenomenal My Defender: http://www.defender2.net/forum/post630322.html#630322
Post #657070 13th Oct 2017 1:59pm
JOW240725
Awesome! Glad you like it as well! Did you go 150AB or 170AB? James
Instagram @suffolk_rovers
Post #657074 13th Oct 2017 2:06pm
Seapod
At the start of the flashing process there was a choice on my phone's screen that basically said - Would you like 150hp or 170hp? Press button to select.
Guess which one I went for.... Razz My Defender: http://www.defender2.net/forum/post630322.html#630322
Post #657076 13th Oct 2017 2:14pm
JOW240725
Ooh, I wonder!! Cool
So if you buy the 170 you get the 150 too? Are you running it with the standard intercooler? James
Post #657078 13th Oct 2017 2:18pm
Seapod
Yes, i now have a choice of 3 maps - Standard, 150 and 170. Its a 5 min job to switch between them.
yes to standard intercooler, at least for now. I don't live anywhere very hot (Devon!) nor do I tow very heavy loads or run at high speeds for long periods (ie motorway miles). On balance this should keep me out of trouble. I will continue to get advice and look at some of the temps (that are available via tool) to get an idea of normal vs raised temps. My Defender: http://www.defender2.net/forum/post630322.html#630322
Post #657101 13th Oct 2017 4:52pm
nitram17
Seapod is the colour of your defender santorini with silver roof?Im amazed how different the defender colours are under different light conditions!
Post #657107 13th Oct 2017 5:29pm
Seapod
Yes a silver roof. I think it's Indus Silver, but don't know for certain. Initially I didn't like it and planned to get it sprayed black but is grown on me as it gives the vehicle a bit of a lift from the all black look (which in my personal opinion can look a bit too gangsta once you change wheels and so on) My Defender: http://www.defender2.net/forum/post630322.html#630322
Post #657121 13th Oct 2017 6:49pm
Seapod
It's zermatt silver, I've just checked My Defender: http://www.defender2.net/forum/post630322.html#630322
Post #657124 13th Oct 2017 6:58pm
nitram17
Is it santorini black?I i have an indus silver roof on mine ..i think the grey looks better as a contrast but like you i am getting used to it!
Post #657152 13th Oct 2017 8:12pm
Seapod
Yes it's santorini black. When I bought it there was a full adventurer roof rack which I have since taken off. The roof is more noticeable now. Still slightly undecided but have other priorities currently for any spare land rover cash! My Defender: http://www.defender2.net/forum/post630322.html#630322
Post #657159 13th Oct 2017 8:48pm
Page 3 of 3 <123
