Home > Maintenance & Modifications > OME shocks / Bilstein ?
Page 2 of 2 <12
geobloke
pannawonica wrote:
geobloke wrote:
-1 for Konis not a patch on Old Man Emu IMHO.
They did not cope very well with the extra weight of the roll cage and the adjustability part is just a gimmick as you do have to remove each shock to adjust. If you do want adjustable shock absorbers then think about those that have a physical switch.
With shocks it's really a case of what works for you. From my prospective the original equipment lasted only too60KKm,s. whilst O.M.E (Yellow Monroe,s) do have a strong following out here Koni have a good reputation for durability and performance. Usually I give the go to OEM, but in this case went too Koni! Originals only going too 60KKm,s was a bit ordinary. My theory its probably the heat out here, two years for battery's and all!👍 Time will tell! Very Happy
I agree entirely pannawonica. With shocks, springs, bushes, tyres, etc. it does really come down to personal experience/preference. I adore old Man Emu shocks, have covered many many 10s of 1000s of miles on them and have just treated the 110 to a full set of their springs and shocks. The difference is superb. The Defender feels fantastic on and off road and the suspension setup is just about perfect (for my needs).
Now before the roll cage and combined with the standard LR springs fitted to a CSW the Konis were very good and I was completely sucked in by the "adjustable" feature of them, buying them over the Old Man Emu shocks. It became apparent though that for them to be truly useful as adjustable shocks then the mechanism of having to in effect remove the shock to adjust them is a massive PITA. This being the case my advice to Chopperone is to go in with their eyes wide open.
Plus there are a number of truly adjustable shocks on the market if that is a truly desirable feature. Personally, however, I find the Old Man Emu setup to be Thumbs Up Thumbs Up
Post #655810 8th Oct 2017 12:34pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
Biffas wrote:
Richard be interested to see if your anti roll bar has rubbed the tank guard my did after a day so i removed it, i had a disco 1 and mine did not drive like that infact my wife said what the F"""" have u done to this she was not happy. Made my back door really rattle as the ride was so hard.
Well I have been under the back end and no sign of any rubbing marks. I did replace with new all the linkages when I fitted it. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #656052 9th Oct 2017 12:52pm
Chopperone
Thanks to everyone for their advice.
I am going for OME but do I need their medium ones?
If I ever went for an adjustable shock set up it would have to be something that was adjustable from the drivers seat.....
Guy May your life be like toilet paper ; long & useful.
Post #656464 10th Oct 2017 10:53pm
Chopperone
Post #656465 10th Oct 2017 10:53pm
MK
I'm not sure if you still can pick different options (valving-wise).
Anyway, in general any gas pressurized shock will give you a harsher ride compared to a only oil filled shock. Of course there is a trade off if going off road, etc. Puma 110" SW
Post #656523 11th Oct 2017 11:34am
Bluest
Why does a gas pressure shock give a harsher ride?
Incidentally, I messaged ARB the other day and they replied to say their new remote res OME BP 51 shocks are in development for Defender. 2007 110 TDCi Station Wagon XS
Post #656615 11th Oct 2017 7:58pm
geobloke
Yes you do have a slight disadvantage on the heat stakes... Wink Have you thought of going remote reservoir if over heating is an issue?
Post #656748 12th Oct 2017 11:56am
pannawonica
Australia
Yes I'm inclined to agree that remote shocks should in theory work better in the heat, however if it's 50C plus then everything that's not in the cab somer or later is at that temperature or more! Very Happy In the pilbara there are quite mixed opinions about OME, Koni too! However truth is as I see it is time will tell, they are much better than OEM. The ride is better and they tow better and seem too cope with the heat! Thumbs Up
Post #657010 13th Oct 2017 10:47am
Chopperone
UPDATE;
I spoke to Flatdog & explained what I was looking for....i.e a lowered defender by approx. 1 - 2" , softer front end on Polybushes on the Front ARB & a stiffer rear ARB coupled to a change of shocks & springs. Also going to stiffen up the drop links.
Ben advised the OME shocks were not suitable & that I should go for Bilstein B6 shocks.
So a phone call to Calum at Alive got me 4 x B6 shocks , 4 x Eibach springs & a steering damper for �710 delivered which I thought was a good deal.
Thanks Callum.
Just need to find time to fit them next. May your life be like toilet paper ; long & useful.
Post #657092 13th Oct 2017 4:52pm
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
Keep us updated Thumbs Up
Post #657102 13th Oct 2017 5:53pm
Page 2 of 2 <12
