Home > Maintenance & Modifications > 110 body off
Cruiser100
110 body off
Hello
New on here guys...back to defender ownership after a long absence.
Bought a 2007 110xs with a pretty rusty chassis. Not rotten just been in the north of Scotland too long!
Going to do the job right and get the body off to get the chassis blasted and either painted or galavanized.
Any advice in taking the body off?
Any threads on here for it?
Cheers!!!
Post #656190 9th Oct 2017 8:31pm
Coatesyyy
Welcome to the forum matey!
Got any photos of the Landy?
If you use the search function at the top you should be able to find something.. Although I'm sure someone more knowledgeable will be along soon to give you some pointers of removing the body Thumbs Up
Post #656194 9th Oct 2017 8:39pm
Scott_Landy
United Kingdom 1993 Defender 110 200 Tdi CSW Firenze Red
Assuming it is a 5 door, you may well need to brace the body with some timber when lifting to avoid any flex.
Plus if the chassis is rusty, might as well have a good poke around on the bulkhead whilst you have easy access. Just in case!
Post #656205 9th Oct 2017 8:53pm
Cruiser100
Cheers Guys
will get a few photos up soon
Probably could get it blasted/repainted with the body on but want to do the job right the first time round!!
Post #656209 9th Oct 2017 8:58pm
thompjas
Done a chassis swap over about 18months ago, fairly easy once you know where all the bolts are and they come undone !
I hired builders 'trestle' tables, some heavy gauge scaffold pole, this was placed through rear wheel arch after jacking the back up and then lowering onto the pole. For the front, I then used a ratchet straps to lift the bulkhead up from its mounting points on chassis - the pictures in the gallery will show how it looks !
Just remember to lift high enough to allow chassis to roll out....
Post #656272 10th Oct 2017 8:26am
JeremyJ
I wasn’t very gentle last time I lifted a body off a 110!!
Post #656408 10th Oct 2017 6:37pm
