![]() | Home > For Sale & Wanted > Tdci improoved Manifold to turbo gasket |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Peter,
vinsell Member Since: 06 Feb 2009 Location: Brindisi (Italy) Posts: 74 ![]() ![]() ![]() |
Where could I find it on Your website? Thank You Vinicio https://google.com/+VinicioSelleri |
nakatanenga Member Since: 12 Nov 2010 Location: Neumarkt Posts: 546 ![]() ![]() |
Not yet online!
You can order through email. WANTED: SII or SIII in max 1.5k |
defender75 Member Since: 06 Nov 2010 Location: Germany Posts: 219 ![]() ![]() |
Can you just put this on or do you need to machine first?
Just put it in. As it is 3mm thick it will compensate a certain warp. WANTED:
What about the other section that connects to exhaust?
never had any truble with that, much lower pressure WANTED:
One last question, can you install this gasket without taking everything apart? If I just removed the bolts is there enough space to move it?
Bomber82 Member Since: 20 Oct 2009 Location: Alessandria - Italy Posts: 216 ![]() ![]() ![]() |
One for me!!
My new ss exhaust needs a better gasket!! ![]() Defender 110 Td4 SE MY 09 |
Ciao Matteo, do You have any whistle? Where do You buy SS system from? Decat pipe too? Vinicio https://google.com/+VinicioSelleri |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
Amazing how a company can steal an idea so quickly ???
Astonishing ![]() 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
Steve,
do you really know how long we were working on this? We started to do this gasket in September 2010. At this stage i did not even know about this forum here! The first 80 gaskets were sold to main dealers which had severe problems with the standard ones. After this we had some problems to get hold of the special material. This was solved in February / March and after this we were able to produce another 300pcs. So, are you still sure we stole any idea? WANTED: SII or SIII in max 1.5k |
Stop being a lard arse you should have produced it then ? NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20612 ![]() ![]() |
^^^^^^^^^ Exactly ![]() ![]() ![]() |
