![]() | Home > Off Topic > Workshop tools explained. |
Silver Back Member Since: 11 Jun 2015 Location: Lincolnshire Posts: 407 ![]() ![]() ![]() |
![]() ![]() ![]() ![]() Love it... |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 ![]() ![]() |
Sounds about right
Coatesyyy Member Since: 07 Sep 2017 Location: Knutsford Posts: 423 ![]() ![]() |
Dammit tool
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1332 ![]() ![]() ![]() |
Love it !!!
Don't forget Conical Drill : A handy device for making that hole just a bit bigger than you intended/needed. Grease Gun : Designed to give long lasting protection to the metal shelving on which it sits between uses through it's magical ability to turn grease into oil. Air Ratchet : A wonderful piece of kit for spinning off nuts in hard to reach places until the nut being removed causes the ratchet to be jammed up tight against an opposing surface, rendering the reversing switch inaccessible. Cheap Air tools : Time saving tools that actually make the job ten times longer than using the equivalent hand tool because every time they are called upon they need a full strip down/rebuild to coax them back into life. Ditto. Mig Welders. |
Rashers Member Since: 21 Jun 2015 Location: Norfolk Posts: 3583 ![]() ![]() ![]() |
Thank you so much. That has lightened my day
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
![]() ![]() Wanted, Forward Control Anything considered. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20661 ![]() ![]() |
![]() β½οΈπ’οΈβοΈπ§°πͺ |
mini Anaconda Member Since: 23 Aug 2016 Location: Thames Valley Posts: 806 ![]() ![]() |
Baz8046 Member Since: 08 Feb 2016 Location: Chatham Posts: 81 ![]() ![]() ![]() |
Some of those sound familiar!
![]() Range Rover L322 TDV8 Westminster 2012 Discovery 4 SDV6 Landmark 2016 |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10902 ![]() ![]() |
Nice one
2T ENGINE LIFT.
That increadably good tool at testing the tensil strength of anything you forgot to undo. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
bluebottle Member Since: 08 May 2015 Location: Not in my Landy enough! Posts: 705 ![]() ![]() |
Excellent!
Chris90V8 Member Since: 02 Oct 2016 Location: Suffolk Posts: 714 ![]() ![]() ![]() |
1st tool that comes outta my tool box at the mo is a BATTERY GRINDER
