Home > Puma (Tdci) > Puma 2.4Tdci White Smoke |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
Has the white smoke started recently?
I'm just thinking it could be weather related, condensation in exhaust? I have had an egr fail that allowed coolant to pass into inlet manifold giving the mentioned symptoms, That would be my first port of call. Head gasket problems are extremely rare, you could always do a sniff test on the coolant to confirm this. Your correct on the chain, they are not Duplex, they are single,but rarely give any trouble, I have changed a few in Transits which were done purely as a precaution as they were close to 200,000 miles. Even at this age they showed no sign of stretching, or wear on the sprockets, I have only ever come across one TDCI engine with a slipped chain, but that was more to do with the oil pump failing, which then had a knock on effect with the chain tensioner. If your chain has jumped,you would defenetly know! It would run quite rough.... 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
9th Oct 2017 8:01am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17337 |
That seems to be normal for a Puma in cooler weather and nothing to worry about.
9th Oct 2017 8:19am |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2637 |
Likely the VCV, see these threads:
http://www.defender2.net/forum/topic50069.html http://www.defender2.net/forum/topic56835.html http://www.defender2.net/forum/topic30222.html http://www.defender2.net/forum/topic55077.html -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
9th Oct 2017 11:10am |
Greg L Member Since: 30 Sep 2013 Location: Alexandria Posts: 46 |
I had the white smoke on start up, but their was lack of egr self scrape cycle when switching off. Also had an intermittent EML for egr valve stuck. Turned out to be EGR valve changed it and all sorted. The white smoke must be over fuelling with the egr set to recirculate when engine is cold to improve warm up time.
9th Oct 2017 9:43pm |
newhue Member Since: 28 Apr 2014 Location: Brisbane Posts: 351 |
don't want to confuse thing as I only have observations. Mine is 2010 185K. Over the past 6 months it has started blowing about 20t of white/light grey smoke on cold start ups left over night. This seemed to be happening 80% of the start ups.
Recently I turned the fuel tanks J pipe breather around. By doing this is has relieved the fuel tanks excessive pressure habits that leave diesel over the fill neck, tank, chassis and so on. But, and I have no explanation why, the white lt grey smoke has stopped. Wondering if tank pressure at the days end causes slow seepage somehow of diesel into a pot, as I believe light grey smoke is unburnt fuel. Car runs fine, using no waterer, good vcv, and no inward vacuum when opening the filler cap. Might be just more forum noise to make the situation harder to workout. But that is what I have found. My Defender and travels |
12th Oct 2017 11:18pm |
