Home > Off Topic > CB |
BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253 |
Where are you going to put the aerial Bri?
30th Mar 2011 11:27am |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
Probably on the roof Mike, but will need to look at the swr for the earth ground plane.
30th Mar 2011 11:29am |
A mag mount? The roof is aluminum though...
30th Mar 2011 11:31am |
Yes, but the rib's are steel
30th Mar 2011 11:32am |
Yes but will it not be cock-eyed? the mount I mean? unless its big enough to cross two ribs?
30th Mar 2011 11:40am |
If it's just for green laning then I wouldnt bother with an external aerial at all, you wont need one. my mount is the one post earlier but you have to drill to fit it. it's not as much of an a******* clencher as you might think
30th Mar 2011 12:05pm |
Really.......... |
30th Mar 2011 12:09pm |
no really as long as you put masking tape over the area, measure it etc, then i just used a sharp punch to create a small depression to stop the drill slipping
30th Mar 2011 12:10pm |
30th Mar 2011 12:24pm |
I'm about to get one of those giant orbitors for our forthcoming trip. I usually use the short one which is fine for greenlanes and better for tree branches etc but for long distance the big one is the way to go
30th Mar 2011 12:27pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5055 |
Brian...i like mine, im sure it will work for you... as i mentioned i have a special clamp, you put it on the glass shut the window and on the outside it gives you a BNC and the inside you get whatever connection you need on the end of a cable.
You then plug in to the unit (i also use my airband transceiver if im on an airfield) and away you go! Mike |
30th Mar 2011 4:34pm |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
Ken i'll have it mate NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
30th Mar 2011 4:52pm |
NoDo$h Member Since: 18 Aug 2007 Location: Buried in deer guts in Dorset Posts: 972 |
Oh cock, why didn't I see this before I popped in to see Ken
54 Freelander modded for mud 2008 D3 SE 2010 90 XS SW 1978 88 Series 3 undergoing surgery with a new owner 2007 90 County Truck Cab - gone 2006 D3 SE - gone 2004 Freelander Sport - gay 1999 Disco V8 ES rotted to bits |
30th Mar 2011 11:09pm |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
Sold to GREENI pending paypal
31st Mar 2011 5:16am |
