Home > Puma (Tdci) > Safari doors and spare wheels. |
Petrovich Member Since: 24 Jan 2008 Location: Sankt-Peterburg Posts: 75 |
In my opinion...
Two Defenders later I found solution for my third one / Click image to enlarge Defender 110 '07 |
8th Oct 2017 12:56am |
UtilityTruck Member Since: 09 Jan 2014 Location: Oxford Posts: 463 |
HD steel wheel and MTR tyre on my '14 plate for 2.5 years- fine to begin with, but toward the end the door became somewhat hard to shut and the latch constantly creaked. I adjusted the latch striker but the problem would always come back. The hinges still appeared in good condition.
Earlier this year I fitted a MOD/LR wheel carrier- very similar to the Mantec part and the door now closes beautifully. Since initially adjusting the latch I've had no further problems. When I fitted the carrier I also took the time to white lithium grease the hinges and latches which also helps the closing, and of course corrosion imho 2014 Keswick Utility 2.2 |
8th Oct 2017 7:21pm |
