![]() | Home > Puma (Tdci) > Which alarm to fit? |
I'm sure it 'll have a factory fitted alarm,some export market cars don't. 2.4 90 XS
mse Member Since: 06 Apr 2008 Location: UK Posts: 5069 ![]() ![]() ![]() |
the alarm is part of an option pack...i think the immobi. is standard - but most models have it Mike |
Pob Member Since: 23 Jan 2009 Location: Midlands Posts: 119 ![]() ![]() ![]() |
Thanks guys but it definitely does not have an alarm of any sort. Spoken with the squealer and he said that it does not have one. He said most aftermarket ones do not work well with defenders so I have had a eureka moment !
. . . . . . . . . . . . . quick release steering wheel! I will get a quick release boss and an aftermarket steering wheel and just remove it and either take it with me or hide it in the Landy out of sight when I park up somewhere. Big deterrent to a thief as even if he hot wires the car he can not steer it. Pob |
sounds a good idea 2.4 90 XS
parktag Member Since: 30 Sep 2008 Location: Brittany Posts: 366 ![]() ![]() ![]() |
I didn't think mine had an alarm, so to test it i sat in the car and locked it with the key fob. Then i pushed the lock up (by hand) and the alarm went off. It's worth a try, just in case. 130 crew cab
98 V8 Disco |
Thanks but no key fob on mine
![]() Going along the quick release steering wheel route I think - gotta be a good way ![]() ![]() |
It would probably help if you left the front wheels on full lock to stop some one towing it away. 130 crew cab
98 V8 Disco |
chalky Member Since: 09 May 2008 Location: Yorkshire Posts: 483 ![]() ![]() ![]() |
have you seen the CLUTCH CLAW !
Had one of these for about 6 years now and always leave it fixed when parked anywhere ! even on my drive. DEFENDER XS CSW 08 TONGA GREEN |
