Home > Puma (Tdci) > oil in turbo / engine breather
v8bobber
United Kingdom 2008 Defender 110 Puma 2.4 DCPU Java Black
Hi all,
Fitted a recon turbo (from Turbo Technics) around 50 miles ago and decided thought I could hear a light whistling so took the inlet pipe off (the plastic 90 degree one that comes off with two bolts) and the turbo seemed to have a fair bit of oil in the bottom.
I can't be sure that the oil isn't coming from the turbo but it looks as if its coming down the oil breather pipe as it's dry between the junction and the air filter.
I've taken the crankcase breather off the top and there just seems to be a diaphragm with a spring in it. Is there supposed to be a gauze or any kind of filter in there? I would expect to see some oil in there but this seems excessive.
Dave
Post #655516 6th Oct 2017 8:54pm
v8bobber
For reference this is the picture of the oil in the turbo....
Post #655530 6th Oct 2017 9:27pm
