Home > Maintenance & Modifications > change springs
carmi
United Kingdom 1996 Defender 110 300 Tdi USW Alaska White
change springs
Hi guys, like to go for softer springs on my 96 110 300tdi . It`s a special made for the environment agency, any one got any idea`s.
Post #655128 5th Oct 2017 2:58pm
jst
its prob got HD ones on it, first thing i would try is Std factory fit ones. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #655170 5th Oct 2017 7:24pm
carmi
Thanks James, I will look in to that at Famous four in Louth.
Post #655286 6th Oct 2017 10:07am
Cupboard
It's pretty easy to do on your driveway if you don't want to pay someone to do it.
Post #655322 6th Oct 2017 12:19pm
I don't my own also. Thumbs Up
I'd look into spring isolators also if I was you for a better ride on OE springs.
You won't be able to do top and bottom on a 110 like a 90 like I did with the castellated rubber type but you can do some and the wrap around type on the rear.
IIRC, on a 110 you can fit the castellated type of spring isolators on the front but not on the rear due to larger spring.
On the rear there is wrap around types instead though.
On my 90 I have top and bottom all around inc wrap around also on the rear.
I'd look at getting new or near new spring Genuine springs too, Chris @ CSK may have some? WeWillWin🇬🇧🇺🇸
Post #655354 6th Oct 2017 1:53pm
carmi
Thanks guys, I think that I will try standards for now. I am a drive way guy. Thumbs Up
Post #655580 7th Oct 2017 10:10am
