Home > Maintenance & Modifications > Wheel bearings
williamthedog
Wheel bearings
During the winter I intend to re-pack the wheel bearings.
Here's the question.
Do I stick with the spacer set up or revert back to the old style with the 2 lock nuts.?
Your supposed to use new stake nuts as opposed to the old method they last forever basically.
Opinions please.
Post #654549 3rd Oct 2017 11:04am
Your choice, you'll get equal numbers in favour of the one and the other.
In my view, the older configuration is preferable since it is easier to service and maintain.
Post #654550 3rd Oct 2017 11:10am
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
I've gone back to the old method on 3 of mine, when the last one starts grumbling I'm going to swap that over too. 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #654582 3rd Oct 2017 1:08pm
williamthedog
Bearings are fine at the moment. That's why I was going to re-grease them or should I just wait till they rumble and swap them over then but I don't want one to fail epically when I'm on a long journey either 🤔
Post #654586 3rd Oct 2017 1:13pm
dorsetsmith
inspection and re-pack wheel bearings with stack nut and spacer not problem
New stack nuts and hub seals ,
Gasket - Drive Flange
if you are having problems bearing use tinken (NP449291 / NP420308) 2x bearing per hub as used by LR
Post #654591 3rd Oct 2017 1:48pm
X4SKP
Hello williamthedog
I stayed with the Spacer / Single Hub Nut System...
Replacement Hub Nuts, Inner and Outer Seals, + Drive Flange Gaskets, and you are set.
If you are just re-packing or even replacing 'like of like' Bearings (introducing new OEM 9146 Bearings)
then the Spacer used (which has been matched to the tolerance of the main Wheel Hub) can remain unchanged.
I did this all round on mine, this year at 25K, and by default you get to check and grease up the Drive Flanges / Shafts also.
Lessons Learnt...(advice taken before the job Cool )
1 Get a good 52mm Socket (I used a long reach Impact Socket)
2 Get a long (strong) Length of Tubing (to fit your Socket Wrench) to 'break' the Hub Nut loose...
(it is really... really tight Shocked )
3 Keep the Inner and Outer Bearings in that arrangement when returned to the Wheel Hub
4 Reset (the new) Hub Nut to required Torque Setting to 210 Nm (150 lbf.ft)
5 You wont 'crush' the Bearings as the Spacer prevents this as Nothing has changed...
(apart from the grease)
6 There is advice to check the Hub Assembly End Float, with a Dial Gauge and using bracket LRT-99-503, when no End Float is present 'stake' the Hub Nut. I didn't do this I just returned the New Hub Nuts to the correct Torque (borrowing a Torque Wrench to get to 210NM as my 'normal' Wrench doesn't get anywhere near those values)
7 All Bearings Checked at 10 and 100 miles... Thumbs Up
Good Luck... SKIP
Post #654595 3rd Oct 2017 2:06pm
dorsetsmith
The only thing to add is step 3A Hub Nut to required Torque Setting to 25 Nm to start with rotate hub forward and reverse and in and out to make shore bearing are seated
drive mender bolts 65 Nm
also see link below for more information
https://1drv.ms/b/s!AtZSoWFHDgnGhQoLf-ZCjkI5M0R7
Post #654604 3rd Oct 2017 2:27pm
williamthedog
Ok cheers for the info Thumbs Up
Post #654608 3rd Oct 2017 2:57pm
tuesdayfox
2013 Defender 110 Puma 2.2 SW Zambezi Silver
I converted the setup back to the old style two nut system when I replaced the rear rotors
For the ease of road side repair.
I inspected the bearings and they are in great shape so I just repack and put them back in.
The things I find amazing is, in my case, land rover did not follow their workshop manual when assemble both my rear hubs. I forget the exact specs for the end float but the number doesn't match those in the manual.
And I hate that stake nut anyway because my torque wrench only go up to 170NM.....And it required 210 Nm
Yes 210 NM
Also if you put the old bearings back with the original spacer, it is probably find. However, say, your bearings are gone and you are going to replace them
At this point, you will also need to purchase a series of spacers to set the correct end float
Post #654722 4th Oct 2017 2:16am
tuesdayfox
Yes 210 NM
Post #654723 4th Oct 2017 2:22am
The stake nut and spacer system is quicker and cheaper and requires less operator skill to build at the axle factory where (I imagine) bespoke and expensive measuring equipment is used to determine the inter-bearing distance and hence identify the appropriate spacer. The hub can then be assembled without further thought by someone with few skills and will be correct.
For the home mechanic the original two nut, no spacer system has clear advantages since it is very easy to assemble correctly with rudimantary skills, doesn't require a stack of difference spacers on hand (or a trip to your local dealer in a three-wheeled vehicle when you find you need one you don't have), doesn't require a sacrifical nut, and, because it doesn't require a large torque wrench (indeed it doesn't require a torque wrench or any special tools other than a suitable inexpensive box spanner at all) becomes a feasible roadside repair. There is no downside to the old system.
A further consideration is that since it is not possible to "unstake" the stakenut particularly effectively there is moderate risk of damage to the stub axle threads, which will not happen with the earlier system.
In my opinion that change to the later system was done purely for economic reasons (cheaper to build and cheaper to achieve a consistent build quality) and the result is less satisfactory in every other respect - less adjustable, less maintainable, and more expensive to repair.
Incidentally I have now twice come across TDCi Defenders which have the original factory hub components and have had no work ever carried out their hubs where there has been excessive play in the wheel bearings, and, on investigation, have found the hub nut to be staked and incapable of movement but less than finger tight. In both cases the bearings were in essentially sound condition, ie not breaking up, there was a spacer in place, so the only fault was that the hub was slack. AS I cannot see any mechanism which would allow this to happen with a correctly assembled hub, and, given that the odds of the only two vehicles mis-assembled both crossing my path must be billions to one against, it makes me wonder how many others left the factory like this. The truly terrifying thing about this is that it means that only the staking on the (otherwise loose) hub nut and the brake disc were holding the wheel and hub on the axle. Shocked
Post #654762 4th Oct 2017 8:37am
williamthedog
Thanks for the replies, I've opted to go back to the old style with the 2 lock nuts because of the simplicity of the design Thumbs Up
Post #654939 4th Oct 2017 6:49pm
jst
2 nuts gets my choice
At least the caliper will hold the hub on, better than a jeep, seen what happens when they break a Shaft! Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #654983 4th Oct 2017 8:15pm
Leviathan
Ive just replaced the rear bearings and brake disc on my Puma. On removal there was the normal stake nut but there was no spacer in between the bearings. Not sure what the implications of that are tbh.
Fortunately the bearing kits I've bought contain both a new staked nut and a normal nut, together with the knock over washer so I've reverted to the old method.
I'm doing the other side tomorrow and assume the spacer was forgotten if theres one in that side.
Post #655632 7th Oct 2017 3:56pm
DOOFER
Yes 210 NM
I think i'll be ok, my torque wrench goes up to 1600nm Smile DON'T PANIC
Post #655653 7th Oct 2017 5:04pm
