Home > Td5 > LT230 electric switches question
MC84
United Kingdom 2001 Defender 90 Td5 HT Chawton White
I have bought a LT230 transfer box to fit to my 2001 TD5 90 truck to convert it from 1.4 to 1.2 ratio. The "new" one came out of a Disco automatic I understand. It has the diff lock and hi/low levers and one switch which actuates when I select diff lock. Reading on the forum I have heard of another switch that tells the ECU what range (Hi/low) you are in and alters the throttle response. Am I correct and I'm missing a switch? Mike
Hard Top 90 TD5 2001
Ford 100e 1959
www.youtube.com/mikemakesit
Post #653749 29th Sep 2017 10:16pm
Martin
Site Admin
Sounds like it. I assume your 1.2:1 box is out of a Series 1 (Tdi era) Disco not S2?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #653807 30th Sep 2017 10:14am
MC84
Hi Martin, not too sure where it came from but could a switch be fitted? Where does the switch live normally? Mike
Ford 100e 1959
Post #653896 30th Sep 2017 6:03pm
dorsetsmith
red line to the low and high switch orange line to the dif lock switch
Post #653927 30th Sep 2017 7:27pm
MC84
Many thanks dorestsmith. What do people do with regards the missing switch? Is it possible to fit one to the casing? Mike
Ford 100e 1959
Post #653950 30th Sep 2017 8:05pm
dorsetsmith
if you are missing tapped hole to fit switch Big Cry
Post #653952 30th Sep 2017 8:07pm
MC84
I'm missing the Hi/low switch. And hole! Mike
Ford 100e 1959
Post #653970 30th Sep 2017 8:31pm
dorsetsmith
do you have pic of your disco Lt230 box
Post #653981 30th Sep 2017 8:50pm
It probably won't matter much not having it, you'll just have the standard throttle all the time. It should still drive ok in low range, just be lighter on the pedal.
Post #653990 30th Sep 2017 9:37pm
MC84
I'll upload a pic tomorrow, at work at the mo! Mike
Ford 100e 1959
Post #654007 1st Oct 2017 12:11am
MC84
Picture of my transfer box. I've circled the place I may be able to drill for the new switch.
 Mike
Ford 100e 1959
Post #654170 1st Oct 2017 5:43pm
dorsetsmith
if you remover six bolts top your box and check in side for High/Low selector finger that moves the switch and Fork-high/low selector
also metal serf from drill and tapping will need clean out good luck
Post #654178 1st Oct 2017 5:58pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Or switch the gear set into your old transfer case... 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #654179 1st Oct 2017 6:14pm
achuakh
Singapore 2002 Defender 90 Td5 SW Oslo Blue
i'm believing that box came out of a disco Tdi300. so yes, you are right, you need to port over the hilow detect switch housing.
when you put the boxes side by side, you will see what is missing and what you need to swap over. it's nothing complicated. i did that on mine. From the land of the most expensive land rover defenders on planet earth. At �125k for a XS 110 csw and you get to own it only for 10yrs! Please find me a good reason to stay on this island.
Post #654374 2nd Oct 2017 4:11pm
If you're swapping the front output housing from one box to another, be mindful of the fact the front diff bearing is in the housing you're swapping. You don't really want to mix the bearing races, and you may need to reshim the front bearing to set the bearing preload due to machining differences between the housings.
Post #654426 2nd Oct 2017 7:35pm
