Home > Puma (Tdci) > Long Range Fuel Tanks
Yannis
United Kingdom 2015 Defender 90 Puma 2.2 CSW Corris Grey
Ciao,
I know this has been covered before but everything I searched came up with extra tanks for 110's
Does anyone know of any long range fuel tanks for the 90?
Year 2015
Yan
Post #628311 1st Jun 2017 9:35pm
rockster57
United Kingdom 2011 Defender 110 Puma 2.4 CSW Zermatt Silver
Post #628318 1st Jun 2017 9:48pm
Avelingporter
I was going to say the same model from Safari Equip who make it. Try ringing Brendan at site sponsors 4x4 Overlander. He can sort for you.
Douglas
Post #628319 1st Jun 2017 9:51pm
West Yorkshire Lofty
Scotland 2015 Defender 90 Puma 2.2 HT Fuji White
Well long range fuel tanks on a 90 is a challenge.
Had the 30l plastic fuel tank from Flatdog (Flatdog) fitted.
Pain in the arse to install but now get 400 miles between fill-up
Cheers WYL 2015 90 Keeper
2005 R300 Keeper
2019 XC40 Shopping Trolley
2008 110 XS Utility (Friday Build) Gone!
Post #628327 1st Jun 2017 10:25pm
I just carry a 20L jerry can... TheThunderRollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #628336 1st Jun 2017 11:08pm
Pilgrimmick
Go down the twin tank route, 90 tank up front and td5 onwards tank at back.
 80" 1948
Lightweight V8
Bowler Tomcat
130 Station wagon
90 300tdi
(Santana PS10 pick up)
Range Rover L322 (Ful fat)
Post #628342 2nd Jun 2017 12:01am
leeds
this could be a possibility.
http://www.4x4overlander.com/product/defen...-30litres/
Regards
Barbara
Post #630400 10th Jun 2017 5:07pm
4wheeler
Australia 2013 Defender 110 Puma 2.2 SW Chawton White
Long Range Automotive in Australia manufacture two sill tanks for the Defender 90. I have had them install a 134 litre long range tank to my Defender 110 today. Excellent quality product.
www.longrangeautomotive.com.au
Post #653362 28th Sep 2017 11:26am
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
The 90 "under the wheel arch" expansion tanks are OK albeit a bit misleading in terms of additional capacity. They replace the filler neck which normally holds around 5 litres so the 30 litre tanks actually gets you an extra 20-25 litres or thereabouts. In real terms, our rear tank went from 65 litres to 85 litres fill up after fitting one of these tanks.
Anther potential issue is that they don't like being used off road, they get caught by your tyres on full articulation and eventually develop a crack and start leaking... currently plucking up the courage to remove ours at the moment for that reason.
They are an absolute pain to fit and the benefit is debatable, there are easier ways to get an extra 20+ litres of fuel on board. I added a standard 300TDi tank under the driver's seat and that is cheaper, easier and more reliable as well as giving more fuel capacity. On a TD5 it means moving the electrics and ECU but on a Puma it's a lot easier.
They make access to the rear lights an absolute pain, ditto the standard load tie down rings in the rear.
It's a nice idea and not a bad design however, for the small amount of extra fuel there are a lot of downsides and unless you think it's absolutely necessary to carry every last drop of fuel, I wouldn't bother. i certainly wouldn't fit one again. http://www.yorkshireoffroadclub.net/
Post #653372 28th Sep 2017 12:02pm
jst
when i looked into this a while back my conclusion for the money was to fit and earlier 90 underseat tank and plumb it into the filler of the std tank for filling with a Y piece and for transfer with second port and separate inline pump. give a switchable sender feed to the fuel gauge, one for each tank. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #653376 28th Sep 2017 12:13pm
X4SKP
Hello Yannis
I too have looked at this several times...and keep coming back to my Jerry Can.
The 90 (from my research) has more limited options than the 110, and whilst potentially
you would free up the space internally (occupied by the Jerry Can)...for simplicity, and potentially
life expectancy over a Plastic 'hidden' long range tank, I think there is an argument for the simpler
solution.
The Puma 90 has (approx') a 56 Lt Tank (some debate here between 55 - 60 Lts... Confused )
which more or less gives a 300+ mile range (56 Lts / 12.3 Gallons @ 24 MPG)
A 20 Lt Jerry Can = 4.4 Gallons = 100+ Miles further range...(this for me is enough)
I have used mine on only two of occasions, once to avoid using a Motorway Service Station, when we had a fuel 'scare' in 2000 when from memory they were charging 10p / Lt more than 'normal'... and once to assist a motorist who had run out (Range Rover...in North Wales)... the 'movable' Jerry Can was therefore of more use (to help someone else) than if all the fuel was 'fixed' on-board.
http://www.defender2.net/forum/topic42699.html SKIP
Post #653387 28th Sep 2017 12:56pm
YOLO110
Australia
Jerry Cans for the 90. Thumbs Up
I carried 5 in my camper trailer across Australia, and 3 more in the Defender. This gave me 160 Litres extra, the same a 4 fill up's... an additional 900Km! Cool YOLO... You Only Live Once...
Post #653401 28th Sep 2017 2:34pm
greenlandrover
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Tonga Green
X4SKP wrote:
Hello Yannis
<SNIP>
That's a nice Jerry Can. Where did you get that from please?
Post #653505 28th Sep 2017 9:09pm
X4SKP
Hello greenlandrover
I 'inherited' it from my wife's Father, but its origin is now unknown...it may be a Polish Jerry Can,
and is probably over 50 years old, based on what we know.
Aluminium Body, Handle and Spout, Steel Closure Mechanism and Steel Flexible Pouring Spout
with a bit of effort it would really polish up well, but its current 'satin' look with a few battle knocks
just looks right... really strong and being Ali' seams right for a Land Rover.
Maybe someone on here may know who made this... Question these are the only markings...
 SKIP
Post #653591 29th Sep 2017 10:14am
jonny2tanx
United Kingdom 2005 Defender 110 Td5 XS CSW Alveston Red
Looks Russian. That's a Cyrillic L after the 20
Post #653702 29th Sep 2017 7:45pm
