Home > Puma (Tdci) > LOUD NOISES!!!!
Farmerben
United Kingdom 2015 Defender 90 Puma 2.2 HT Keswick Green
LOUD NOISES!!!!
After 8 months of no dramas, 'Fender now making two odd sounds that I can't really find discussed anywhere else.
First is like a creaking /plastic-y knocking/creaking sound under the driver's footwell (also can feel it through my feet). Happens on any uneven ground - even slightly wobbly tarmac. It doesn't sound anything like the noise it would make if a bush had gone and doesn't seem to be any play in the shafts.
Second is a weird noise under acceleration. Doesn't happen all the time but is almost like an electrical/deep kazoo sound from the engine. Can't explain it.
I've got audio recordings of them - just need to figure out how to get them from my phone onto here. Got the motor booked in for a service but can't get me in until the 2nd Oct and my curious mind has got me a bit worried. https://instagram.com/bentheoandrews
Post #652977 26th Sep 2017 5:08pm
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
You should be able to upload them onto youtube as there's music on there 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top
1958 Series 1 Soft-top
Post #652982 26th Sep 2017 5:30pm
Grenadier
Re: LOUD NOISES!!!!
Is the creaking not the floor Plate moving or flexing? Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #652986 26th Sep 2017 5:43pm
agentmulder
Kuwait
I had an underfoot one for a while.
I'm away from my vehicle at the moment so cant climb under to take a photo of the offending bolt, so I simply suggest getting under there and tighten all the body to chassis fasteners you can see in the area. I think in the end it was a long bolt that hold quite a few bits together, it goes right through the first outrigger aft of the front wheels... Solved the bowel problem, working on the consonants...
Post #652990 26th Sep 2017 5:52pm
LR90XS2011
I've had the same type of underfoot creak for 4 years tried many times but failed so for to trace it, there is a complete thread on here about it somewhere, DEFENDER 90 TDCI XS,
Post #653008 26th Sep 2017 6:50pm
agentmulder
Kuwait
The bolt I refer to was ruddy tight when I found it, but cracking it and doing it up a snip more solved it after all.
Depending on how patient you are you could try a penetrating lube in the area, or giving each questionable spot a well measured tap with a hammer to see if you change it's creaky characteristics (could make it worse ha ha, or I suppose a bottle of fizz could drop out too) Solved the bowel problem, working on the consonants...
Post #653010 26th Sep 2017 6:57pm
Farmerben
Thanks everyone for the suggestions.
Got the Landy in the dry this morning for a good poke around its undercarriage. Looks like whoever put mine together forgot his 10mm spanner. Pretty much every 10mm nut was loose underneath. On limited testing seems to have done the trick. https://instagram.com/bentheoandrews
Post #653091 27th Sep 2017 7:44am
