![]() | Home > Tdi > 200tdi - slow - not pulling great/pump tuning does nothing!? |
With that set up, you're expecting too much. Apart from the rack and lift that add to wind resistance, 285/75 tyres are a good four inches taller than the standard 235/70's fitted to Discoverys. You're massively over-geared - in the region of 13% - so comparing it to your 90 really doesn't mean much. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Normal stuff like filters, cleaning the intercooler and perhaps new hoses. The sorts of things that degrade over time so it's not immediately noticeable that something is less than ideal.
I agree about the 245's. I just wanted you to be aware that if you've already noticed an issue then it'll be made worse by fitting bigger tyres, even if they look right on a Defender. By way of comparison, my factory original 200tdi 90 on 7.50 tyres (essentially the same height as 265/75) will pull 5th gear from 40mph and continue on to 70mph without issue. It's done 159k and I know that the intercooler needs a clean out, so I expect it to be even better when I get chance to do that. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
yostumpy Member Since: 01 Aug 2010 Location: n/kent Posts: 327 ![]() |
exactly what size tyres do you have, there is mention of 285's but the op mentions 265? confused, with 265's you have a gutless problem that is /could be mechanical, with 285's its the gearing. what size tyres on your 90 'that flies'.
benniferj Member Since: 20 Oct 2016 Location: Basingstoke Posts: 361 ![]() ![]() ![]() |
The 90 that flies is on 285/75/16s
The Disco is running a lot better now it's been used more regularly - it was sitting for the best part of a year. I cleared the sedimentor filter at the back as well as running a few doses of injector cleaner through it. It's running a lot better although still no where near as gutsy as the 90. That engine is just manic compared to my Disco's one. Either way I'm over it - and not putting tiny wheels back on it... it's a 'get about' hack for a bit of laning and in my work I do a lot of stuff at festivals as I'm a live sound engineer - great to be able to pull everything else out of the mud! I think there may be something funny going with the pump as I simply can't tune it to smoke... I expected to be able to get it to plume black smoke so I can wind it back in from there. The 90 was easy - turn the boost diaphragm and low smoke screw too far and it plumes smoke so you get a visual representation of what your limits are (aside from EGT and Boost gauges) The Disco just won't smoke... which is weird... tuning these pumps is normally easy. That said I'm achieving and holding 70 now which isn't bad. |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2706 ![]() ![]() |
Is the fuel metering pin moving freely?
If you remove the diaphragm and plunger/cone assembly (noting orientation) from the injector pump boost compensator housing and then actuate the throttle lever you should see the metering pin pop out into the cavity, where it would usually ride on the eccentric cone. If it's seized in the pump body it can restrict power on boost, depending on which position it seizes in. |
I need to check that fuel pin still anaconda.
I did notice yesterday while doing a quick fluid check that if I revved the engine I could see the top IC hose squidge a little bit. Thats not even with the vehicle driving of course, just on a hard rev parked up - should you ever be able to see the hose squidge at all or do you reckon that is stifling the engine on hard boost? Replacing the hosing is no issue... apart from I need to find where I put all my spare hoses... I reckon I will put a solid pipe there with just silicone joiner ends... |
Defendermatt Member Since: 15 Sep 2016 Location: Derbyshire Posts: 313 ![]() ![]() ![]() |
I would suggest using hard pipes with silicone joiners if you have done some tweeking.
Is what I do when I get the chance to.
I'm just intrigued as to if this slight squidge I can see when not under much load at all will be enough be stifling my engine explaining what is happening to my acceleration... Simply do good condition pipes squidge at all or not? |
