![]() | Home > Technical > EGR blanking |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20654 ![]() ![]() |
It should be inlet side really.
![]() β½οΈπ’οΈβοΈπ§°πͺ |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8182 ![]() ![]() ![]() |
that was the plan, but does it matter which end of the cooler? drivers side seems more accessible rather than taking the valve off Cheers
I've only heard of fitting EGR end, and is this way on mine. Recommended by Alive.)
You should be able to slip the blank in from the side and only loosen the bolts. The tricky bit is getting the bolts back in and the gasket once removed completely. But you won't have that, as most blanks you can slip in from the side. ![]() Click image to enlarge TheThunder Rollsπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
thank you Steve, so on that picture it goes next to the cooler rather than on the flexi down pipe fitting?
Out of interest how many miles on that vehicle - looks chocked! Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Yes, cooler side. Gasses are from exhaust manifold through cooler, through egr exiting the flexipipe. Mileage that was only around 36k (I can't quite remember) I'm on just turned 60k now. I replaced the EGR for brand new and it went under not 6 months later again. Since I also now run Millers diesel additive too. You'd be surprised how dirty they get TheThunder Rollsπ¬π§πΊπΈ
β½οΈπ’οΈβοΈπ§°πͺ |
i have some EGR faults and this vehicle is on 60ish K so time to blank i think, thank you, hopefully plates are in tomorrow. Cheers
Let's us know how you get on.
Access not actually that bad, all loosened valve end of cooler, just waiting on parts Cheers
