Home > My Defender > An Anoraks Tdi Defender 90
Page 19 of 24 <123 ... 181920 ... 222324>
bluebottle
Very neatly and elegantly done Thumbs Up
Post #652522 24th Sep 2017 10:55pm
Procta
how is the repair holding up on the heat shield? my dads asking as he has his off and I think he may look at repairing it. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #652546 25th Sep 2017 6:09am
Ellisboy
1998 Defender 90 300 Tdi CSW Epsom Green
Nice fix for the rear seats Thumbs Up that�s probably one of the most annoying noises! Mine are held together with a bungee.
Stephen.
Post #652557 25th Sep 2017 7:31am
A couple of bungees would have undoubtedly been a quicker fix Laughing
Only covered about 130 miles in relatively short journeys since that repair but so far, so good. I've got a longer run coming up this weekend, which will be a better test.
On a vaguely related note, a few weeks ago I posted about replacing an exhaust heat shield, which also included repositioning it to what I thought was the correct place. This has made a huge difference to the cabin temperature, with the gearbox tunnel now no longer too hot to touch after a run! Darren
Post #652558 25th Sep 2017 8:08am
Rear Door
After a couple of weeks of steady preparation and parts collection, this afternoon I've finally fitted a new, later rear door to my 90, complete with matching later style hinges. The old door came off easily enough, but the old hinges put up more of a fight, needing three of the six bolts drilling out Rolling Eyes
The paintwork around the old hinges is quite poor too, but sorting that out will have to wait for another time.
Whilst most of the parts are second hand, I've used all new stainless bolts and made rubber gaskets to fit between the hinges and the body and door.
The bolt kit came from SP4x4 and includes the three nut plates, which are quite nice.
The one part that I did buy new is the lock. This is a pre-TD5 version that takes the narrower lock barrel, which I wanted to match the rest of the vehicle. It has a gasket made of closed cell foam between it and the door itself.
With the new door on its' hinges, I then fitted all of the various ancillary components. The spare wheel carrier was also given a fresh coat of paint and again I made rubber gaskets for the mounting points.
This was bolted on with new stainless flange head bolts.
On the inside, instead of the large washers used in a standard install, I made up some spreader plates from 3mm aluminium.
The wiper motor, wiring loom bracket and door stay were all fitted, with the latter matching up with the existing tub bracket, which was an unexpected bonus.
With everything in place and the lock and latch adjusted, I then fitted the plastic door card and internal grab handle. The card that I've got is a bit battered and if I find a better one I'll replace it, but if not I may have a go at painting it.
The finished article. It's great to have a door that doesn't need to be slammed to make it close!
Ran out of time to fit the spare wheel but I also want to make a bracket to install a Tuff Lift, which I may get chance to do tomorrow.
The only other outstanding task is to make a wiring loom for the electrical equipment, but again that'll have to be a job for another day! Darren
Post #653755 29th Sep 2017 11:54pm
Chris90V8
England 1987 Defender 90 2.5 TD XS CSW Portofino Red
⬆ ⬆ ⬆ ⬆ coming along really nicely Thumbs Up 🚜. ...... . .... . .. 🚗🚐🚛🚚🚚🚗🚙🚐
Post #653764 30th Sep 2017 2:26am
Procta
is the rear door a later one? looks a stronger one than mine Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #653766 30th Sep 2017 5:43am
Yes, it's the post '02 pressed steel version. Much stronger and galvanised so shouldn't rust! Darren
Post #653774 30th Sep 2017 7:14am
Ellisboy
Nice job Thumbs Up ,need to do mine next year
Stephen.
Post #653777 30th Sep 2017 8:25am
Thanks Smile
Here's a better picture in the daylight:
 Darren
Post #653793 30th Sep 2017 10:10am
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
A good mod/upgrade to mount the spare wheel carrier with the long spreader plates on the inside of the door rather than the large washers Thumbs Up
Post #653803 30th Sep 2017 10:40am
defender9
I like the rear grab handles, we're they an option on Defenders or Series?
Post #653804 30th Sep 2017 10:43am
Yeah, Deluxe option from Series days.
http://www.defender2.net/forum/post569194.html#569194 Darren
Post #653826 30th Sep 2017 1:22pm
okennedy
Ireland
Great reading on the thread, absolutely love threads like these. The 200tdi is looking brilliant, very nifty but intelligent work being carried out - very neat indeed!! Thumbs Up Thumbs Up
Post #653835 30th Sep 2017 2:21pm
Thanks Smile
Just a couple more to finish this bit off: the last thing to do was to mount the spare wheel but to avoid messing up my new paintwork, I made a rubber pad to fit to the carrier out of an offcut of the 5mm matting used for the rear load bed.
And with the wheel finally in place:
The door shuts with a nice, satisfying 'thunk' and doesn't need to be slammed anymore, which is nice. Darren
Post #653848 30th Sep 2017 3:54pm
