Home > Puma (Tdci) > Haynes Manual - Puma |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4655 |
Page 1.2
ROUTINE MAINTENANCE AND SERVICING 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
23rd Sep 2017 1:33pm |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 981 |
Thanks but I meant the box posted by X4SPK. BTW in my one on page 1.2 the capacity for a MT62 is 2.2L which I thought was correct. Do you think they have corrected this edition?
Merlin https://www.defender2.net/gallery/albums/u...earbox.JPG |
23rd Sep 2017 2:01pm |
The 2.2L is correct but it states to fill the gearbox until oil runs out of the filler hole, It says it's a "filler/level" plug hole. This is incorrect. If you fill until it runs out of the hole there will be too much in the gearbox. It also states to check the illustration 13.4. The illustrations on 13.4 are of the switches on the steering column. 1982 88" 2.25 diesel
23rd Sep 2017 2:19pm |
flydive Member Since: 27 Aug 2015 Location: Lugano Posts: 290 |
Well, received mine last week.
Yes, quality not the top, the restoration one is way better. Still, it could be useful as I'm quite new to the Defender. As here we have quite a few knowledgeable people, why not start a sticky with all the errors spotted and corrections? |
25th Sep 2017 6:04pm |
Bergos Member Since: 08 Aug 2015 Location: Somewhere in Portugal Posts: 95 |
I have received mine 30 minutes ago.
Well... I am disappointed... The subjects covered are less than basic... Bergos LR Defender 110 HT 2007 (2.4 Puma) https://www.facebook.com/LR.Wanderlust/ |
29th Sep 2017 10:48am |
Farmer58za Member Since: 20 Jan 2017 Location: Worcestershire Posts: 85 |
Got mine today:
Yes, paper and photos are not great. It is completely lacking in On-Board Diagnostics, something that should be an essential part of the manual for a vehicle like this. It does not even say where the OBD II port is. Some transmission sections are left out with a "Here Be Dragons" warning on them. Still, at GBP16.54 in my hands, it's good value. Regards David Dave's not here man... |
25th Oct 2017 5:36pm |
nitram17 Member Since: 08 Jun 2014 Location: newcastle Posts: 2261 |
Its only good value is the content is correct!Somebody may speed read the transmission bit and use the fill hole as a level and overfil!....its a shocking error!.....not quite world ending but still disappointing!
25th Oct 2017 8:17pm |
Edited by Gerry McGovern? 1982 88" 2.25 diesel
25th Oct 2017 9:13pm |
As I said above, why not create a sticky listing all the errors found and corrections? That would help a lot newbies like me. |
26th Oct 2017 11:55am |
Fernando Member Since: 25 Oct 2017 Location: CABA Posts: 92 |
He recibido el mío hace 30 minutos.
Bueno ... estoy decepcionado ... Los temas tratados son menos que básicos ... |
26th Oct 2017 12:44pm |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2295 |
Hello Merlin...Sorry I missed this request... The 'picture' showing the Oil Capacity was taken from the Defender Owner's Handbook, (so not out of the Haynes Manual ) There are two references to Capacities for the Transmission in the Handbook... Page 64 Click image to enlarge Page 94 Click image to enlarge Hope this helps... SKIP https://www.defender2.net/forum/topic83242.html |
26th Oct 2017 12:47pm |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1232 |
Just be careful with it and don't take everything it tells you as gospel. There are some errors regarding the Puma engine that don't make sense and its only when you cross-reference with the actual Workshop Manual that you find that they are talking about the TD5 Engine. There could end up being some very costly mistakes made for the uninitiated!
26th Oct 2017 3:20pm |
PEM406 Member Since: 08 Nov 2017 Location: Hampshire Posts: 2 |
Thanks smb. Just got mine today and reading through. I’m a newbie on engines, only touched bodywork and basic electrics so thanks for the warning.
8th Nov 2017 8:13pm |
Great idea ....perhaps pm Martin ..Haynes probably would not be to happy though oif it turns into a very long thread1 |
8th Nov 2017 9:01pm |
