Home > Puma (Tdci) > Leaking on pasenger floor
Page 2 of 2 <12
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Heater vent is on the same side wether it is RHD or LHD.
Post #65134 25th Mar 2011 11:31pm
defender75
2009 Defender 110 Puma 2.4 XS CSW Chawton White
The heater box would be either left hand or right hand side depending on the drive. I looked at the pics in the other thread and at my truck and can not find the teets.
Post #65136 26th Mar 2011 12:29am
Grockle
remove the intake vent on the wing top, put your hand in, it will prob be full of water at bottom near the back you'll feel a rubber teet in the base push a finger through to clear it out,there is a seocnd teet in the round part of the blower box.
hope this fix's it for you Thumbs Up 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #65141 26th Mar 2011 7:12am
mse
Mine it was very much the seal between heater box and seat box water was running down the bulkhead and in
You may also want them to replace the bits rusting under there aswell! Mike
Post #65143 26th Mar 2011 8:43am
defender75
Cleaned my top teet. I need to see if that does it.
Thanks for the info so far.
Post #65212 27th Mar 2011 1:09am
gtveloce65
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Epsom Green
My old Td5 leaked through the seal under the bulkhead to screen bracket cover (if that's an adequate description of it). Was coming through the bolt-holes and running down the inside of the dash then appearing as an accident in the foot-well in surprising quantities...fixed under warranty (but had it been out of warranty I'm sure some clear sealant would have done the trick) 1953 80
1965 Alfa Romeo GT Veloce Sprint
1980 Fiat 124 Spider
2008 110xs
Post #65775 31st Mar 2011 4:38pm
Page 2 of 2 <12
