Home > Puma (Tdci) > Leaking on pasenger floor
defender75
2009 Defender 110 Puma 2.4 XS CSW Chawton White
Anyone care to explain why my truck gets a puddle on the passenger floor when it rains. I thought maybe it was coming through the door but based on these pics I think it is coming from the top of the kick panel. Any ideas on how to stop it before I have rust I can't fix?
thanks
[/img]
Post #65027 24th Mar 2011 9:33pm
110SEB
Is that the Holy Grail I can see in one of those pictures? Oh no. Just my imagination Rolling Eyes
Water ingress farce manual on Google. Have you heard the one about the Mitsubishi and Land Rover air-con and the cat?
Sorry for the weirdness, but I've given up on this one! Winscreen seal, aircon system, roof condensation, door seals, windscreen hinge bolts...
Post #65031 24th Mar 2011 11:09pm
defender75
I have seen egress manual and if this wasn't a puma I would look for the obvious places. I mean it could be coming from the door seal and traveling over the top of the kick panel and running down. I have seen water do worse in rain. I need to take a hose to it. The interior light plunger screws are all rusted as well.
Post #65037 25th Mar 2011 3:24am
Grockle
check the drain teets in the blower box these often get clogged up 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #65052 25th Mar 2011 7:57am
defender75
Do you have pics of what they are? I have never seen them before. How do I clean them.
Thanks
Post #65082 25th Mar 2011 2:31pm
bob neville
From the pictures it looks like mine when it was leaking badly.
The foam seal between the bulkhead and windscreen had to be replaced by the dealer. It fixed that leak and all I have to do now is stop the leak on the passenger door seal - new door rubber has not sorted it !
Bob
Post #65083 25th Mar 2011 2:49pm
mse
When mine did this they removed the wing, removed the heaterbox resealed and refitted...it leaked in exactly the same place and they had tried the other things first (just to waste my life) Mike
Post #65088 25th Mar 2011 4:45pm
defender75
It is amazing that it leaks. I don't think it is coming through the seal for the windshield to heaterbox but who knows. It could be the door seal but am not sure. I would like to see the drain holes I should check if anyone has a picture.
thanks
Post #65090 25th Mar 2011 4:53pm
mse
thanks
THere isnt a seal between heaterbox to windscreen Wink its heatbox to bulkhead or windscreen to bulkhead. or windscreen seal
Whilst the door seal could be the problem (possibly look for kinks and where the heater routes) - i doubt its that Mike
Post #65091 25th Mar 2011 5:34pm
defender75
I meant bulkhead to windscreen. I miss the old style heaterbox you could see if there was a leak. IN the puma I have no clue what is under the hood and don't have a dealer I am close to.
Post #65115 25th Mar 2011 9:57pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Your not on your own mine needs a new bulk head
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #65126 25th Mar 2011 10:53pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Earlier thread had these pictures showing the Heater box drain holes"-
http://www.defender2.net/forum/topic5842.html
Post #65127 25th Mar 2011 11:08pm
defender75
You really need a new bulkhead? Come on. Clearly same leak though
Post #65130 25th Mar 2011 11:15pm
defender75
Looking at that other thread what do you clean the teets out with?
Does it matter as far as orientation my truck is lhd?
Post #65131 25th Mar 2011 11:19pm
fekete
you could be right... Ive been waiting 12 months for this as the dealer has not sorted out the body shop ? Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #65132 25th Mar 2011 11:20pm
