![]() | Home > Puma (Tdci) > Traction control? |
cinstone Member Since: 29 Nov 2010 Location: Stourbridge Posts: 375 ![]() ![]() ![]() |
Did you notice any spining up of the tyres at all? It only lights up when it's actually in operation, so maybe it wasn't needed.
Chris. |
Depends what model it is, county spec didn't have ABS or traction as standard it had to be specified. Lock up the brakes on some grass and see if you have ABS is a quick way of telling.....................Oh and leave some foxes for the hounds
![]() 110 HCPU Tipper |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5059 ![]() ![]() ![]() |
If it has TC (and ABS) the quickest way of telling is seeing what lights come on when you put your key to PII - you should have the ABS and the Tyre symbol in yellow Mike
Or perhaps you are a demon driver and automatically drove where you could find traction so the Tallent Controll was not required ![]() ![]() |
david110 Member Since: 11 Dec 2009 Location: Stirlingshire Posts: 81 ![]() ![]() ![]() |
Thanks for the positives (talented driver) but it doesn't have TC or ABS its only the XS model that has all this unless it's been specified.
willy eckerslike left you some foxes. |
