- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
rallysteve
90 2.5TD Oil Cooler Fitting | |
Hi all,
My V8 project has a new 2.5TD radiator with the built in oil cooler. I am having real difficulties working out what thread the fittings are though.
The radiator has brass end tanks which have bosses with internal threads. I am not fitting standard hoses so dont want to buy the 25quid each adaptors. I just want to fot aero type fittings straight in. Took a punt at the threads being 1/2" BSPT (tapered) and ordered a couple of fittings. Sadly the fittings delivered are much larger, although it seems the threads in the radiator are larger. An M16 bolt seems to be around the right size but too coarse. The thread gauge shows the pitch being 1.25 or 1.3 which is a particually stupid pitch. I would also have thought it would be imperial (BSP). Does anyone know?
Cheers Steve 02' 110 TD5 Double Cab Rebuild Thread
13th Sep 2017 6:34pm |
rallysteve
For future reference, it is 3/8" BSPP 02' 110 TD5 Double Cab Rebuild Thread
18th Sep 2017 3:04pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
