Home > Maintenance & Modifications > defender 90 SW Window Rattle (fixed)
Djcla
Hi
Is there a simple fix to the windows in the back rattling like they are going to smash as i increase speed or drive over rough ground?
Post #649565 11th Sep 2017 12:08pm
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
Renewing the felt in the runner would be the best option but it's a pain to do with the glass in situ.
http://www.woolies-trim.co.uk/p-1649-window-channel.aspx
I wedged a piece of cardboard into the slider to stop the rattling a few years back. 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #649577 11th Sep 2017 12:47pm
glpinxit
Post #649588 11th Sep 2017 2:33pm
Djcla
will this stop you using the windows right?
Post #649590 11th Sep 2017 2:45pm
trickster5000
United Kingdom 1989 Defender 90 300 Tdi CSW Arles Blue
Probably not a recommended fix but I used a hot glue gun. I still wanted to be able to open and close the windows so I opened the window, put some small blobs on the side of the groove sort of where the felt used to be, and then while the glue was still hot, just opened and closed the window quickly back and forth until the glue had cooled. It made a nice tight fit in the groove.
Key there is to not get distracted while you're doing it else you'll end up with a window that'll definitely never rattle again... it won't open either Laughing Matt.
'89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html
Post #649627 11th Sep 2017 6:01pm
VeeTee
Netherlands
It is possible to do it in situ. Here's how to do it: http://www.nickslandrover.co.uk/defender-s...placement/
I replaced the felt some years ago this way, no rattling since... Wink Thumbs Up Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #649645 11th Sep 2017 7:12pm
Djcla
That's doesn't sound that easy, wanna do mine lol
Post #649656 11th Sep 2017 7:36pm
VeeTee
Netherlands
it was't that difficult - much easier than the official way by taking the windows out!
 Cheers, Vincent
MySite
Post #649658 11th Sep 2017 7:42pm
Djcla
http://www.masai4x4.com/all-land-rover-def...y=18520778
This would fix it too right lol , I'm quite tempted by the dark tinted glass on the back
Post #649662 11th Sep 2017 7:50pm
Djcla
I went the Woolies window felt route for anyone interested.. extracted the old stuff easily enough with a small screwdriver and patience. Bought the 10mm stuff from Woolies (link below). It was fairly easy to feed through the top tbh and not as bad as I thought it would be. For the corners I just cut little triangles out and ran it around . I found 3m was plenty for the 2 windows as I have the plastic runners in good condition along the bottom edge still.
I haven't road tested yet though Smile
https://www.woolies-trim.co.uk/product/1649/window-channel
Post #683952 3rd Feb 2018 10:03pm
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
What length of felt trim do you need to do both the windows?
Post #711971 11th Jun 2018 9:06pm
Djcla
I used 3m of trim as parts of my windows have these metal runner things as well at bottom but I expect yours are same. , I wouldn't have said it's rattle free but pretty good replacement.
Post #711972 11th Jun 2018 9:10pm
Mike c
England 2004 Defender 90 Td5 CSW Belize Green
Easy fix / bodge Whistle is to cut the head off a plastic cable tie and insert the remaining part of the tie into the channel, under the window. This tip was out of a recent issue of LRO mag, it worked for my rattling window and happy until I can get some masai replacements at some point Thumbs Up
Mike
Post #712199 13th Jun 2018 2:49pm
Djcla
Under the window into the felt channel do you mean?
Post #712208 13th Jun 2018 3:49pm
Mike c
Yes it would be the felt channel
Post #712218 13th Jun 2018 4:34pm
