![]() | Home > Maintenance & Modifications > Wiring in a Voltmeter |
I was reminded the other the day that whilst I have a voltmeter in my dash, I've never gotten around to connecting it up (too many projects, not enough time
![]() ![]() Click image to enlarge It obviously needs an ignition live supply but does it need to be 'clean', i.e. a dedicated connection from an appropriate point on the use board, or will it work just as well with just a tap into something nearby? Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Bushpig Member Since: 07 Nov 2013 Location: Risca, Wales Posts: 236 ![]() ![]() ![]() |
On my Puma, I took the feed from the cig lighter.
But that is quite a distance on yours... Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so. Douglas Adams 2012 2.2 Puma |
The cig lighter feed is doable if that will suffice. It's easier than the fuse box
![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 ![]() ![]() ![]() |
Pretty sure the wires are there on the TDi instrument loom. Black and brown cables with bullets.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
Hmm, not sure. I have had the complete dash out and don't remember anything obvious. The gauge is earthed, as there was a terminal for that but it needs a live with spade connector to complete it.
![]() Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Looks like thw white wire with the female bullet terminal to me. Just need the linking wire with a male bullet and spade terminal. This wire would have come with the gauge originally.
Ah, possibly. I'll take a look later. Darren
