Home > Wheels & Tyres > Going to alloys from steels
Djcla
Evening folks
Now I have some alloys what do I need to buy to fit 4 boost alloys and spare on the back? I've got the standard 5.5 steels at the moment.
Post #648340 4th Sep 2017 10:07pm
HardCharger
You need alloy wheel nuts and I think there is something to add to the safari door (it escapes me right now) in order to properly mount the alloy wheels or else they will wobble.
Post #648353 5th Sep 2017 3:04am
Djcla
20 X nuts and 5 locking wheel nuts is that right?
Post #648362 5th Sep 2017 6:48am
Lightningtweeds
Scotland 2008 Defender 90 Puma 2.4 CSW Stornoway Grey
Some vehicles with factory fitted steels have no ARB'S and handle like a duvet with a space hopper on each corner when fitted with alloys. My County spec TD5 had ARB'S when poverty spec Commercials never.
Post #648368 5th Sep 2017 7:09am
Djcla
Sorry what is ARB and how do I check if I have them?
Post #648369 5th Sep 2017 7:12am
Lightningtweeds
Anti roll bars. A quick look under front and rear should be evident.
Post #648371 5th Sep 2017 7:14am
Djcla
Can see a bar at the front which I assume is what you mean I'll take pic later, cant see on the rear though. Is it essential then?
Post #648373 5th Sep 2017 7:21am
Lightningtweeds
Sounds like you are looking at the track rod.
Post #648375 5th Sep 2017 7:24am
Djcla
Not sure tbh I'll take back pic later
Post #648376 5th Sep 2017 7:27am
Bluest
I can't see why changing from steels to Boosts would have much, if any, effect on the handling. 2007 110 TDCi Station Wagon XS
Post #648381 5th Sep 2017 7:31am
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
I can't see how it would either, when I went from 235s to 12.5" it didn't cause a significant change in handling, more so road noise? So just changing the wheel should have little to zero effect, if anything it should be better as the alloy wheel is much lighter. 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top
1958 Series 1 Soft-top
Post #648382 5th Sep 2017 7:36am
Lightningtweeds
Post #648384 5th Sep 2017 7:39am
Bluest
I understand the pros and cons of the anti roll bars, but that isn't really connected to whether or not the car has Boosts or steels. Perhaps the slight increase in tyre width that comes with Boosts made LR believe an ARB might be helpful in an extreme high speed situation, or more likely it was just some notional idea that the more "sporty" wheels should be accompanied by more road biased handling.
What I'm saying is that changing from one wheel to another really won't make a make a material difference to how it feels to drive. If the OP is happy with the current suspension, then no reason to think that will change. 2007 110 TDCi Station Wagon XS
Post #648387 5th Sep 2017 7:56am
Lightningtweeds
Probably correct that. Steel wheeled Defenders are more likely to be used by farmers therefor need articulation over comfort?
Post #648388 5th Sep 2017 7:59am
Djcla
Does this help no idea what looking for tbh but sounds like it's not a problem anyway. Still not sure on my original question either lol
Post #648390 5th Sep 2017 8:30am
