Home > Maintenance & Modifications > front doors refuse to stay open |
They're the bolts. I think i did them on my Puma, i don't remember them being difficult to get at mind you.
Without looking i can't remember how i did it. Either i just put a spanner up from underneath or undid the screws at the end of the dash and pulled it away from the bulkhead a bit - don't be shy with it, it's quite flexible. |
4th Sep 2017 5:59pm |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3745 |
^ Did it last night
There is a little torx screw a bit higher up on the plastic which I loosened off to make bending the plastic back easier to fit a screw driver socket in. Both sides very lose Easy fix |
5th Sep 2017 8:41am |
I think i put some thread lock on mine as they always work loose again over time.
5th Sep 2017 9:59am |
Thing is I have put up with them not opening and 'clicking' open for 18 months....
such a simple fix for once |
5th Sep 2017 10:06am |
