Home > Maintenance & Modifications > Bulkhead rust drivers side
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
Hi guys, any tips on how to remove this rust in the best and easiest way possible? Unfortunately i gave my door seal a squeeze (as you do) and it felt all crunchy so i lifted it up to find this...
As its not visible i was thinking about dremmeling it out with a wire brush attachment best possible then using some dinitrol rust converter then covering in dinitrol wax.
Thoughts?
Post #647950 3rd Sep 2017 12:03pm
foxyred
England 1994 Defender 90 200 Tdi HT Montalcino Red
Where is the water getting in Windscreen rubber or door seal ? That's the first thing that needs sorting, Then all rust sanded back before treatment then repainted and job done ,
Just trying to apply a rust treatment is a waste of time and money
Post #647952 3rd Sep 2017 12:15pm
LandymanStefan
Its coming i from an ill fitting door seal but i dont want to do one job without the other if you get me, no point in fitting a new door seal and filling it up with rusty bits. As you mention sanding this is ideally what i'd want to do but what concerns me is that some areas are where 2 or 3 bits of metal are sandwiched together so sanding between these layers is basically impossible, this is why was thinking a dremmel with a rotary wire brush attachement seems like my best bet....
Post #647966 3rd Sep 2017 1:29pm
foxyred
Clean the rust off the surface and as much as you can, paint the laminated sections wont rust any further one you have remove two of the things that cause rust,
oxygen and H2O
Post #648064 3rd Sep 2017 8:36pm
