Home > Maintenance & Modifications > TD5 Wiper motor removal |
You need to remove the motor from its' mount and then remove a plate from the rear that secures the end of the drive tube.
This is a tdi motor but the principal is the same: Click image to enlarge Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
31st Aug 2017 3:14pm |
Interlet Member Since: 10 Oct 2011 Location: Norwich Posts: 461 |
Ahh I see. Cheers Anorak. I'd removed it from the mount, but was perplexed by the next stage! Thanks! 1998 110 300Tdi White Hard Top
31st Aug 2017 3:17pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6102 |
Or, if you remove the wiper arms themselves, you can pull the inner cable right out of the "tube" that runs between the wiperboxes (remove the wiper arms because the shafts will spin around a lot when you pull said cable out)
Be careful though, it's a long greasy messy thing... use rubber gloves and maybe another pair of hands to grab the end. good time to re-grease it when you reassemble it. |
1st Sep 2017 6:11am |
epictrail Member Since: 20 Sep 2013 Location: High Wycombe Posts: 395 |
This thread might help you
http://www.defender2.net/forum/topic46094....er+working |
1st Sep 2017 7:28am |
Thanks guys. I didn't realise the white switch on top of it can cause the entire thing to stop working... given the motor was just still getting hot, I have a feeling I might get away with just that park switch. 1998 110 300Tdi White Hard Top
1st Sep 2017 9:06pm |
