Home > Maintenance & Modifications > NAS LED rear indicator lights |
doublea Member Since: 12 Jul 2011 Location: Aberdeenshire Posts: 495 |
Not cheap, but the only ones that match led stop/tail on Adventures (Perei).
http://www.mudstuff.co.uk/products/electri...cator.html You'll need the variable relay too. I'm waiting for their next 15% off everything weekend to get mine. Current Steeds: 2015 110 UW in Grasmere Green 2003 BMW F650 the Hack 2000 Elise 1992 Ducati 888 (no longer in bits, yahoo) 1990 TDR 250 (in bits again) 1988 TDR 250 (no longer in bits) and for sale |
31st Aug 2017 9:28pm |
Greannach Member Since: 30 Oct 2013 Location: Scotland Posts: 18 |
carbuildersolutions.com is where I got mine as they were cheaper than MUD but you will have to buy the connectors elsewhere and fit them yourself; the plinths they supply are not pre drilled for the Defender either. They are from exactly the same manufacturer it's just MUD prepare them for use on the Defender.
For economy - CBS, for ease of fitting MUD. I find the RDX LED indicator relay (It's about 30 quid) from eBay seller boltonbits to be the best as it allows the trailer warning light to work properly in my TDCi, unlike any of the competition including MUD's version. The LED lights are slightly more slimline in profile than the original 95mm NAS lamp so the plastic lamp guards that fit the originals don't look right on the LED versions, as I found out! I have a box of six lamp guards lying around in my garage because they didn't look right . Zermatt Silver 2.4 (with Alive stage 1 remap) TDCi 110 Double Cab Pick Up Everything in life is somewhere else, and you get there in a Landrover. |
1st Sep 2017 7:57pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20466 |
Definitely go for the RDX Relay.
Regarding plinths, Stacey007 on here had some good slim ones recently he fitted to his. However, don't quote me on compatibity with these lights here I'm just merely suggesting it to look at. There should be something on the 'search' function here somewhere. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
1st Sep 2017 8:33pm |
vogue se Member Since: 24 Jan 2008 Location: Bocholt Posts: 112 |
Tx for the info.
4th Sep 2017 7:09pm |
