Home > Off Topic > Brickie question
shanecl
Ireland 1989 Defender 90 V8 Petrol CSW Auto Firenze Red
Brickie question
Hi Folks,
While not exactly Defender related these piers are going to hold up the gates to protect my Landrover Very Happy
I'm going to build two piers 2.2mtrs tall, is their a limit to the height you can go with bricks per day to avoid squeezing out the mortar,
Thanks,
Shane
Post #646940 29th Aug 2017 11:23am
HK07
England 2007 Defender 90 Puma 2.4 HT Cairns Blue
Hk07
One story of a building in one day is quite normal.
Your piers will be fine in one day. 2007 90 Puma - Love it - Best car I have ever owned.
1989 Ninety 200tdi - Love it - Second best car I have ever owned.
1951 80" Series 1 - Love it - Third best car I have ever owned.
Post #646944 29th Aug 2017 11:33am
Sockpuppet
If they're there for protection consider making them hollow and filling with rebar and concrete (depending on how thick they are).
Post #646947 29th Aug 2017 11:43am
zsd-puma
The mortar dries and firms up pretty quickly once you get going, though obviously takes a day or so to reach full strength.
Laying the bricks you're not going to be squeezing the mortar out, but give it atleast a day before before you start trying to hang the gates or drill holes in it.
Good point, or sink and RSJ into the ground and brick around it.
Post #646948 29th Aug 2017 11:46am
X4SKP
Hello shanecl
Worth checking the planning requirements (local to you).
Some years now (when we did this) but Fencing / Gates (of any material) in the UK
is limited to 1M directly adjacent to the Road 2M elsewhere...
To go above this requires Planning Permission (I think)
Good Luck... SKIP
Post #646949 29th Aug 2017 11:49am
shanecl
Thanks for the reply guys, so I could get a good run on a Saturday
I'm standing an IP160 beam inside the piers and hang the gates off them, the brick will just be a clad.
The yard is at the back of the house and well off the road
Post #646966 29th Aug 2017 2:04pm
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
It depends to a certain extent on how good and consistent you are at mixing mortar Thumbs Up
Post #647061 29th Aug 2017 8:39pm
Bows
Wales 2006 Defender 110 Td5 SW Alpine White
I'd be very impressed if a novice bricklayer managed to build a pillar over 2 metres high in a day. Gauge your mixes so you get consistent colour with your cement. I'd Leave them for a couple of weeks minimum before attempting to fix anything to them. Thumbs Up 2006 TD5110 station wagon
1995 300Tdi 90 truck cab
1989 90 hard top with 200 tdi
1983 110 hard top
1983 110 Hi cap
1954 107 pick up
Post #647074 29th Aug 2017 9:34pm
alwoodley72
England 2008 Defender 130 Puma 2.4 HCPU Alaska White
^^^ what Bows says, leave for a week before any hanging/drilling unless direct to beam, piers are tricky to build, make sure you use plenty of plasticiser for a smooth and wet mix, good luck!..
Cheers alex 98 300 tdi 90 project
94 Range Rover vogue 4.2 lse
79 911 sc
08 130 double cab utility
Post #647084 29th Aug 2017 10:29pm
Ellisboy
1998 Defender 90 300 Tdi CSW Epsom Green
What they say and don't forget to lay them frog up Thumbs Up
Stephen.
Post #647102 30th Aug 2017 6:25am
shanecl
was only messing about the Saturday Smile . bring me back to my teens labouring on a Saturday and holidays.
I still have to make the gates so judging on my free time with two daughters could be a long time and well set lol.
Thanks again guys for all the replies
Post #647196 30th Aug 2017 2:35pm
