Home > For Sale & Wanted > [For Sale] Set of Defender 90 Springs |
greenlandrover Member Since: 09 Jul 2017 Location: Stourbridge Posts: 145 |
Any chance you can list the coloured splodges on the springs please?
I'd be interested if they were standard duty springs. Have a CSW but has HD springs. Apparently any vehicle with factory fitted towbar also gets HD springs. I never intend to pull anything heavy so would like standard springs to try and make a softer ride (relatively speaking). Cheers, Jason |
29th Aug 2017 10:13am |
Culminator Member Since: 30 Apr 2013 Location: West sussex Posts: 305 |
Just had a look and the fronts are Red/Green/Orange
Rears are White/Green/Pink Just a bit of googling shows that this is for CSW 2,550KG Cheers Mike Last edited by Culminator on 29th Aug 2017 10:28am. Edited 1 time in total |
29th Aug 2017 10:19am |
Cheers Mike
Will check mine and the docs and see what's what. |
29th Aug 2017 10:28am |
Just updated the above as you posted. Spring colours indicate they are for CSW at 2,550KG.
29th Aug 2017 10:29am |
Thanks again Mike,
I'm not sure what weight is classed as HD. There's a document on here that lists all the spring colours. Will do a search later and get back Cheers, Jason |
29th Aug 2017 10:58am |
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 |
Click image to enlarge 1993 200 Tdi 90 CSW 1956 Series 1 Hard-top 1958 Series 1 Soft-top |
30th Aug 2017 3:16pm |
